I'm still trying to resolve why I get odd fuel level readings and so connected a multimeter between the two male spades on the sender unit whilst fitted in tank and earth and power wires are still connected. Turned on ignition (orange and red lights lit) without starting car. The multimeter reported voltages between 0.5 - 4.8 with voltage fluctuating between these values. Then repeated with another known good sender unit and same values repeated.
Is anyone able to confirm if this is normal or should I be getting a static constant reading and if so what should the value be.
Many thanks.
Kevin
Edited by KevinS, 06 March 2022 - 03:41 PM.
