Hi All,
Looking for advice.
I took the rear subframe off my 1984 mini last night and I ended up chopping off one of the bolts as the captivated nut sheered off inside the chassis.
Is there an easy fix for this, I know it is part of the vertical panel that is under the rear seats but I was hoping I don't have to cut that whole panel out and replace.
Its one of the front subframe mounts that bolt in on the rear of the sill.
Thanks all
