Clutch Pedal Pressure
27 replies to this topic
#16 mini13
mini13
  • 3,810 posts
Posted 01 April 2022 - 02:22 PM
the cylinder inline was a damper to prevent violent disengagement
#17 Spider
  • 14,892 posts
Posted 01 April 2022 - 06:32 PM
Metros had a 5/8" master compared to  3/4" on a Mini. I've used one with a Pre-Verto & pre '76 pedal box.
It's been a very long time since I needed to look at mine, but yes, they are indeed 5/8"
GMC1010
https://www.euspares...rts/lpr/2361742
Good shout.
#18 croc7
croc7
  • 813 posts
Posted 01 April 2022 - 08:07 PM
Thanks for the information. My engine is (was) a Metro 1275, so should be an easy swap. They are fairly hard to find but I did find a NOS one out of Cypress, of all places. Did it make a noticeable difference in pedal pressure?
Edited by croc7, 02 April 2022 - 01:42 AM.
#19 Spider
  • 14,892 posts
Posted 02 April 2022 - 02:32 AM
It should make the pedal about 12% lighter - if that's any help.
BUT
Before going down this road, just be sure you have enough pedal over-travel now or you might find you can't completely disengage the clutch.
#20 croc7
croc7
  • 813 posts
Posted 02 April 2022 - 06:17 AM
Thanks, Chris. Is that an adjustment at the clutch lever stop, the throw-out stop (at .125”) or combination of both??
To prevent damage to the crankshaft thrust washer, I thought that the .125” measurement at the throw out stop was set in stone.
J
Edited by croc7, 04 April 2022 - 03:28 AM.
#21 Ethel
  • 25,951 posts
Posted 02 April 2022 - 12:03 PM
I have to admit I can't say how much lighter because I never tried it (grey diaphragm) with a Mini cylinder. I thought it was on a par with other clutches. Of course it will take more pedal travel to disengage, so could be more vulnerable in that respect - it'll help if there's no excess slack in the clevis pins etc. fitting a braided hose should also help a bit & possibly a residual pressure valve - as long as the release bearing... releases, if you get my drift.
Not 100% sure, but I think the MGF could use the same cylinder.
..oh and it also takes a M10x1 union.
While I'm brain farting: a 2 inch diameter wastegate actuator could produce about 30lbs of force from manifold vacuum.
#22 Ethel
  • 25,951 posts
Posted 02 April 2022 - 12:18 PM
BUT
I thought more
5/8 is 16mm 3/4 is 19mm (ish)
πr2 > 8x8 = 64, 10 x10 = 100, so roughly a third less area = 2/3rds the force but 1.5 times the distance.
#23 croc7
croc7
  • 813 posts
Posted 02 April 2022 - 09:39 PM
[quote name="Ethel" post="3717160" timestamp="Lll
While I'm brain farting: a 2 inch diameter wastegate actuator could produce about 30lbs of force from manifold vacuum.[/quote]
M10x1 union? Where? Into the MC. If so, I might be in trouble….
Edited by croc7, 03 April 2022 - 12:19 AM.
#24 Ethel
  • 25,951 posts
Posted 03 April 2022 - 10:07 AM
Actually, I got that wrong...
It isn't 10x1, it's 12x1!
Probably simplest to make up a pipe. You can get the unions on fleabay, or an adapter to 10x1, or a banjo.
Forgot I sleeved mine to use one of Minispares' braided hoses with banjos.
...also did some internet digging & found the same part number for the MGF repair kit, so they likely are the same.
#25 mini13
mini13
  • 3,810 posts
Posted 04 April 2022 - 08:02 AM
Interesting thought!
#26 Ethel
  • 25,951 posts
Posted 04 April 2022 - 09:48 AM
...you'd have to invert the push to pull, but there's  plenty of cheap spangly ones on Fleabay.
#27 mini13
mini13
  • 3,810 posts
Posted 04 April 2022 - 10:24 AM
Well, i did have a vac one off of a VNT, but to be honest i think the stroke might be a bit short on an turbo actuator, but i think Ive got an old air ram lurking.... something like in the link. would be easy to couple in with a rose joint etc etc...
https://www.ebay.co....kp:BFBM4LPKwf5f
#28 Ethel
  • 25,951 posts
Posted 04 April 2022 - 11:06 AM
I was thinking the other way, that a ram could be too long. You can sort that out with leverage though - the link looks good , if pricey, the extruded cylinder could be cut  to size - as long as you can get it to seal.
