Everything is running fine. No overheating. However, I discovered a pool of coolant after having car parked for a while. Coolant is leaking at rate of 2-3 drops a minute.
I traced to the water pump area but it is dry. Found the joint from radiator hose to engine block wet but I could not assess if that is the source of the persistent leak or just wetting.
I tried pressurise the car by running the engine. However, there was no leak. Everything seems fine.
Other than the hose, are there other possibilities?
