Fluidless Clutch
Best Answer DavidN , 28 April 2022 - 04:40 PM
Correct! Very slight film of fluid on the back of the pedal.Must have taken 2 years to drain the reservoir. Little sign on the carpet though. Refilled and "bled" It'll keep to the next MOT visit.Thanks for your help. Go to the full post
Posted 27 April 2022 - 03:05 PM
Posted 27 April 2022 - 03:15 PM
You will have a leak somewhere.
Posted 27 April 2022 - 03:38 PM
I'd check inside the car, where the master cylinder arm is.
Posted 27 April 2022 - 05:41 PM
Thanks for your replies. Yeah I guess either it wasn't in there in the first place or it's come out! I'll recheck for leaks. I'm of an age where I outsource my little jobs to the local garage now. (52 years of Mini ownership...) I'm wondering, given the low mileage since it's last change, that it wasn't filled correctly. It really is bone dry and I wonder if it could operate for a while on a minimum amount before giving up. Didn't check. I'll refill and do a bleed. ( avoiding all the paraphalia that's in the way on the MPI...).
Posted 27 April 2022 - 06:30 PM
If you can't see an obvious leak, it's usually the Master Cylinder and it'll be leaking in to the carpets.
Posted 28 April 2022 - 04:40 PM Best Answer
