Originality is not important to me. Why not just weld one thicker plate back on instead of the two original, and rust prone, thinner lapped panels?
Scott
Posted 28 April 2022 - 08:45 PM
Posted 29 April 2022 - 07:05 AM
Posted 29 April 2022 - 08:29 AM
This area also is commonn for rust because the shock mounts were usually fitted at the factory before the bodyshell was painted.....as Hydrolastic Minis had no front shock mounts this area did get painted.
Posted 29 April 2022 - 11:46 AM
i did this on mine, this area always rusts, just remember to drill holes to plug weld to crossmemeber. hold plate to crossmember with self tappers while welding
Posted 29 April 2022 - 01:07 PM
My feeling is if you repair it as it was originally designed but using some rust prevention on the assembly it should be good anyway. I put a bead of seam sealer around the shock mount to prevent moisture getting back in there and you can spray cavity wax in there once welded up.
Mini Technical Sections →
Bodywork, Paint and Detailing →
Wheel Arch Repair For MotStarted by adman020 , 21 Jun 2024 ![]() |
Non- Genuine Door HingesStarted by CBJ805T , 09 Jun 2024 ![]() |
Where To Start - Rear EndStarted by OzKopite , 03 Mar 2024 ![]() |
Mini Specialist For Welding -South East/south WestStarted by s2ulk , 20 Oct 2023 ![]() |
Wheel Arch/boot Floor Repair HelpStarted by austinmayfair85 , 10 Aug 2023 ![]() |
