Alfa Rear Seats - Where To Cut?
Posted 16 May 2022 - 12:36 PM
I try to fit some Alfa seats in my 91 Cooper. But I'm a bit in a struggle with where to cut them.
I grüß I have to Cut the metal bars and some foam. But I think they will become very flimsy?
Maybe if anyone has a picture of their Cut down rear seats?
Posted 16 May 2022 - 03:46 PM
The seat needs a little extra padding undernearth to fill out the shape of the bench if I recall correct.
Posted 16 May 2022 - 08:46 PM
Posted 16 May 2022 - 10:24 PM
Do you find that with the front AND rear seats in the mini there is literally no leg room in the back? Not that I’ll sit in there that is. Thinking of just putting the standard mini rear seat in for more room. Obviously front seats are Much deeper than original mini ones, but there are nice and comfortable.
Posted 16 May 2022 - 10:34 PM
Posted 17 May 2022 - 03:39 PM
Back to original question where to cut? not sure why you need to cut, i shaped the centre plastic to follow contour in backrest of car and bolted each side through backrest into boot, made parcel shelf to also follow contour as this will now be seen, for the base i made a bracket each side bolted to existing seat base floor, where backrest finishes each side there is a strip which also shows which i covered with vinyl, wheel arch covers made in black leather with red stitching.
I used original front spi seats, all covered to match, black leather with harris tweed.
Hope this helps.
Posted 15 June 2022 - 09:05 AM
Posted 17 June 2022 - 07:54 PM
what alfa are these out of?
Posted 18 June 2022 - 04:37 AM
The front seats so have seatbelts mounted which have to be removed!
