difference between
Posted 10 November 2006 - 04:33 PM
Posted 10 November 2006 - 04:36 PM
Posted 10 November 2006 - 04:48 PM
They are not 'stronger' than helical gears as some may suggest, but they do cut out on the side loading that occurs with helical gears (this is also the reason that they lose less power, as more is transferred to rotating force).
Posted 10 November 2006 - 04:49 PM
Posted 10 November 2006 - 04:56 PM
USE THE SEARCH, IT IS YOUR FRIEND!
Nah, seriously, sorry to shout, but there have been loads of topics (some of em really good if you filter through them) on this very subject. Have a read through them all, you'll learn alot.
I don't think they have any synchromesh on any gears either?
and yeah, they do have syncros
Posted 10 November 2006 - 04:59 PM
OMG! Seriously, I used to joke that no one else could see the search button, but now I'm beginning to think its true...
Perhaps it should be mahoosive and red?
Posted 10 November 2006 - 05:59 PM
ooh oh search i cant see the big red button above
Posted 10 November 2006 - 06:06 PM
Posted 10 November 2006 - 06:16 PM
Posted 11 November 2006 - 10:57 AM
Manufacturers but helicoil gears in cars for a reason, and not because they've pretty or much more expensive to make, it's infact because you increase the contact area between each gear wheel and generally have three teeth 'meshing' at a time. This reduces load on any one tooth and makes for a mroe reliable and longer lasting gear set.
Straight cut gears do indeed reduce friction and side loading, and are more efficient, however they're not as reliable, long lasting, or quiet.
As an aside, most cars have straight cut reverse gears, which is what gives you that whining noise, and mini's (and metro's, etc), have straight cut first gears! Which is how you can tell it's a mini pulling away when you can't see it!
Hope that helps!
Dave )
Posted 11 November 2006 - 12:58 PM
A full answer for once.
Hope that helps!
Dave )
now thats the perfect answer that could'nt of done better meself
Mick ...
Posted 11 November 2006 - 12:59 PM
Hope that helps!
Dave )
Mick ...
Of course it's perfect, I'm a professional! :-P
