Drilling Holes In Airbox
Best Answer h9hpj , 04 June 2022 - 07:35 PM
Thanks for your comments - air box drilled and k&n filter installed. Sounds lovely now without the drone from the old cone filter.
Go to the full post
30 replies to this topic
#16 Steam
Steam
  • 951 posts
  • Local Club: Victorian Mini Club
Posted 27 May 2022 - 01:30 AM
Dsn classics do one.
#17 Ol timer
Ol timer
  • 329 posts
Posted 27 May 2022 - 11:48 AM
Hi all, In my experience, drilling holes to the bottom hasn't noticeably increased performance on a stock 998. Instead I machined up a ram pipe that fits over the opening to the airbox. The design is based on the optimum ram pipe airflow geometry which pulls in air from 360 degrees including from behind the opening. Above all else it tidies up the airbox and makes it look less incomplete with the steel flappy paddle intake missing.
Any chance of seeing a photo of your ram pipe setup
What is your email address? I'm struggling to add images to this vintage forum interface haha.
kberlyn@prodarts.com.au
#18 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,186 posts
  • Name: Neil
Posted 27 May 2022 - 01:53 PM
Trying using Imgur, it’s free to use and easy to set up.
#19 stuart bowes
stuart bowes
  • 2,602 posts
Posted 27 May 2022 - 08:12 PM
https://imgbb.com/ is free and requires no set up
you just drag/drop your image onto the first page, choose 'don't delete' and then choose 'full image BB linked' which produces a code you copy and paste into your comment
picture added job done
#20 beardylondon
beardylondon
  • 1,776 posts
Posted 28 May 2022 - 01:18 PM
Ive got the DSN classic one, as I also wanted to tidy up the opening
https://www.dsnclass...if-carb-airbox/
Edited by beardylondon, 28 May 2022 - 01:20 PM.
#21 Maccmike8
Maccmike8
  • 1,101 posts
Posted 28 May 2022 - 01:41 PM
#22 D 'n A
D 'n A
  • 99 posts
Posted 30 May 2022 - 07:45 PM
It’s a no brainer, I use this example when I deliver my su training to dyno operators, drilled airbox is better in every case and the bigger the engine it’s fitted to the more it’s needs drilling.
Ac
A.C. I have this mainstream Cooper airbox. I currently run it without a snorkel. The inlet is large enough. Is this a good idea or would it be better to put the snorkel back on and drill holes to achieve higher airspeed at the airbox entrance?
Edited by D 'n A, 30 May 2022 - 07:46 PM.
#23 h9hpj
h9hpj
  • 42 posts
Posted 04 June 2022 - 07:35 PM   Best Answer
#24 ACDodd
ACDodd
  • Mini Docs
  • 2,835 posts
Posted 04 June 2022 - 07:48 PM
In answer to D n A that filter will be fine put to around 80hp ish, you may be throwing a lbft or two away below 2500rpm without the snorkel on , but don’t fit the pipe which goes ar cross the rocker cover that’s restrictive even at 65hp.
Ac
#25 GT Jimmy
GT Jimmy
  • 1,671 posts
  • Local Club: S.U.N.M.C
Posted 02 February 2023 - 03:02 PM
Very helpful info here, I'm going back to the original airbox and was looking for info on drilling the airbox. Cheers
#26 GT Jimmy
GT Jimmy
  • 1,671 posts
Posted 13 February 2023 - 09:21 PM
Ac
Hiya AC, my engine is a 1310 with an Evo 1 cam, hif44 on a Howley inlet with a cone filter. Will be swapping to the original airbox with a k+n filter.
My question is, should I jump straight in and drill the 6 holes or maybe do 3 or 4 then see how it goes, cheers, Jimmy
#27 ACDodd
ACDodd
  • Mini Docs
  • 2,835 posts
Posted 13 February 2023 - 09:55 PM
Drill lots.
Ac
#28 GT Jimmy
GT Jimmy
  • 1,671 posts
Posted 13 February 2023 - 10:59 PM
Cheers AC. I'll do the six
#29 ACDodd
ACDodd
  • Mini Docs
  • 2,835 posts
Posted 14 February 2023 - 07:38 AM
Drill more than six, drill the periphery 3/4” holes around 2/3’s of the circumference of the airfilter.
Ac
#30 GT Jimmy
GT Jimmy
  • 1,671 posts
Posted 14 February 2023 - 06:04 PM
Thanks for the advice, I'll book rolling road session then fit it when I turn up
