Lucas 65D.
18 replies to this topic
#1 Kongsvik
Kongsvik
    Starting My Mini Up
  • 4 posts
Posted 25 May 2022 - 10:13 PM
Hey!
So, tried searching the forum for answers.I did not quite understand it all so here it goes:
Specs:
Standard Metro 1275 engine, hiff44 carb, BDL needle.Lucas 65d dizzy with a 143 coil. Set the timing to 8 BTDC at 950rpm and then adjusted at 4000rpm to 32degrees. (Vac disconnected).
I have been struggling with the mixture, but after changing to the BDL needle its been much better and i therefor moved on to the ignition system.
The problem is that i am struggling to get the car to perform properly, in 4th gear it seems to flat out at around 4000rpm.
My understanding after reading here is that this is a more suitable coil: https://simonbbc.com...0-DLB102-SILVER ?
But, do i need the ballast resistor or not?
Also, in terms of wiring. I now have the two wires from the electric module on the dizzy to the coil. And a wire that gives 12v when the ignition is on. Will the same setup work with the new coil and will changing the coil maybe fix my problem?
Regards
PK
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,762 posts
Posted 26 May 2022 - 07:04 AM
Use NO ballast resistor with the 65d dizzy.
You likely need a proper tune up to get the engine to run cleanly.
Check out the video below
https://youtu.be/rck8uPyaZKw
Ac
#3 Kongsvik
Kongsvik
    Starting My Mini Up
  • 4 posts
Posted 26 May 2022 - 07:50 AM
Ac
Super,thanks for the quick response:)
Regards
PK
#4 PeterG
PeterG
  • 38 posts
Posted 26 May 2022 - 01:44 PM
I have a similar setup but 1380, 65D, Hiff44 with BDK and std spring. My problems went away when I ditched the conical K&N and added the HIF44 elbow with a standard filter box from a late model HIF38 carb mini, I modified the filter box removing the flapper assembly, sealed off the bottom opening and removed the internal plastic to improve airflow where the flapper was positioned, then added the correct K&N filter. It also removes the induction roar. I found the BDK better than the BDL
#5 chuee
chuee
  • 158 posts
Posted 08 November 2022 - 01:25 AM
Does that mean you were left with only the small bore horizontal  tube at the top of the air filter  for air intake?
#6 croc7
croc7
  • 814 posts
Posted 08 November 2022 - 08:27 AM
Ac
#7 croc7
croc7
  • 814 posts
Posted 08 November 2022 - 08:38 AM
In the video, I thought I heard AC say that the 0.8 coil was correct for use with the 65D dizzy, but I seem to recall an earlier post on this forum where his recommendation was the Vioer 1.5 ohm coil for the non ballast 65D. Or does the application depend on engine modification, etc.?
Edited by croc7, 08 November 2022 - 08:39 AM.
#8 Lplus
Lplus
  • 909 posts
Posted 08 November 2022 - 10:38 AM
In theory the 0.8 ohm coil is correct for the 65D but I've seen a post on here recently by A C Dodd saying that the modern coils are rubbish and to use 1.5 ohm coil instead but still with no ballast resistance in the circuit.  (advice which I have taken)
#9 cal844
cal844
  • 9,630 posts
  • Local Club: TFMOC
Posted 08 November 2022 - 11:02 AM
See AC Dodds YouTube video on the subject, very informative
#10 ACDodd
ACDodd
  • Mini Docs
  • 2,762 posts
Posted 08 November 2022 - 12:46 PM
Just to clear this one up the right coil resistance is 0.8ohm. I have had failures using both 1.5 and 0.8ohm coils and failures with coils too. The most powerful spark will be using a 0.8ohm coil. If you run the 1.5 ohm coil reduce the plug gaps to 0.028” this will reduce the load on the coil insulation and ensure a sensible service life.
No ballast is used with the 65d dizzy
Ac
Edited by ACDodd, 08 November 2022 - 12:50 PM.
#11 PACINO
PACINO
  • 764 posts
Posted 08 November 2022 - 03:35 PM
ACDodd, what about 123Ignition dizzy? Have you used it? Do you like its curves o do you prefe a 65d or a traditional points dizzy?
Kind regargds
#12 ACDodd
ACDodd
  • Mini Docs
  • 2,762 posts
Posted 08 November 2022 - 05:20 PM
The 123 is an excellent unit and has curves I supplied,
Ac
#13 PACINO
PACINO
  • 764 posts
Posted 08 November 2022 - 06:32 PM
ACDodd,what curve (0123456789 A B C D E F) do you think is the right one for an Austin Mini 1275 (now 1293cc) from 1972,twin carb and big cylinder head valves. Final drive very very short.
123Ignition (with vacuum tube).
Cheers in advance!
Edited by PACINO, 08 November 2022 - 06:46 PM.
#14 ACDodd
ACDodd
  • Mini Docs
  • 2,762 posts
Posted 08 November 2022 - 07:06 PM
Start with curve 6.
Ac
#15 chuee
chuee
  • 158 posts
Posted 09 November 2022 - 09:22 AM
Ac
Cheers. I checked that video out, as well as other sin the series, and saw no example of the modified air box, I.E. removing the flapper assembly, sealed off the bottom opening.
