3 in 1 oil is too thin. Burlen sell a specific oil, which I believe is SAE 20.Sensor is welded into the exhaust just as the downpipe bends horizontally under the car. Dash pot oil is 3 in 1.
I figured it may be the needle but aren't all needles profiled to get richer as you put your foot down? Seems mines reversed lol
3in1 is an SAE 20 oil. Too thin. The OP needs to experiment with different oils in the dashpot to get it set correct for the carb. My bet is 20w50 engine oil as this is how the car came from the factory
SAE 20/50 is SAE 20 at low temperatures such as are experienced in carb bodies which are working. Having compared the two oils just now I can state that 3 in 1 is noticably thinner than the Burlen SU oil, which Burlen state is SAE20
