Electronic Smiths Speedo Not Reading Below 20Mph
18 replies to this topic
#1 Hedgey
Hedgey
  • 179 posts
Posted 05 June 2022 - 11:11 AM
Hi guys, I haven’t posted on here for a while.
After having issues with my old speedo I took the plunge and bought one of the 90MPH Smiths digital speedos hoping for a reliable reading
Unfortunately it doesn’t seem to work until I’m going 20MPH or more. The needle stays firmly on the 0 until I hit 20MPH and then it jumps into life and is fine at higher speeds
I changed the speed sensor today thinking it might be that but no luck.
Do all these speedos behave this way or is there something else I can try before going back to the supplier?
Elliott
#2 Shaun78
Shaun78
  • 71 posts
Posted 05 June 2022 - 11:37 AM
Hi,I will say I don't know much about these,but do they need calibration with like tyre size or diff ratio.
#3 Hedgey
Hedgey
  • 179 posts
Posted 05 June 2022 - 12:07 PM
Hi, I forgot to mention the gauge is calibrated to the car and reads perfectly accurately at anything above 20MPH
#4 Ethel
  • 26,761 posts
Posted 05 June 2022 - 12:50 PM
Interference? Play about with the routing of the wiring and/or add some shielding, or improve the earthing of any shielding there is already.
#5 Hedgey
Hedgey
  • 179 posts
Posted 05 June 2022 - 02:02 PM
I did wonder that. I have taken an earth straight from the battery so it definitely has a good ground. The wiring runs from the back of the radiator next to the wiper motor and into the centre speedo. I can’t think of anything that would interfere but I will add som secondary shielding
#6 PoolGuy
PoolGuy
  • 980 posts
Posted 05 June 2022 - 02:06 PM
They need a sensor with 8 pulses per rev to read at very low speeds. The common 6 pulse sensor shows the issues that you're having.
#7 Hedgey
Hedgey
  • 179 posts
Posted 05 June 2022 - 02:25 PM
Interesting, I’m using this sensor https://www.digital-...plications-p432
This was supplied with the Speedo from Digital speedos
#8 PoolGuy
PoolGuy
  • 980 posts
Posted 05 June 2022 - 02:54 PM
Yes, that's the one that I bought too. I chucked it because it didn't read below 20mph, replaced it with one from Sailes https://sailesmarket...x4h-transducer/ It reads from walking pace. Speak to Matthew he'll make one to suit the Mini, it's about £60.
#9 Hedgey
Hedgey
  • 179 posts
Posted 05 June 2022 - 03:01 PM
Thanks I’ll take a look at them
I’ll contact digital speedos as well as the original speed sensor was supplied as part of a kit from them. I also purchased a second one thinking I had damaged the first one.
#10 mrmeds
mrmeds
  • 266 posts
Posted 05 June 2022 - 04:21 PM
slightly off topic sorry - mine reads fine.... but never registers full .... do you have issues with that aspect ?
#11 Hedgey
Hedgey
  • 179 posts
Posted 05 June 2022 - 05:28 PM
Is it a digital one as well?
What doesn’t register full?
#12 PoolGuy
PoolGuy
  • 980 posts
Posted 05 June 2022 - 05:44 PM
Fuel gauge?
#13 mrmeds
mrmeds
  • 266 posts
Posted 05 June 2022 - 07:42 PM
digital..... it only registers 3/4 when full- and the fuel sender has been changed......   also get random flicking of the needle from to max , then min, then back to the correct speed again ( a bit like when you switch engine on )
#14 Spider
  • 15,819 posts
Posted 06 June 2022 - 06:25 AM
There was a sensor that was being sold by Mini Spares for a while that had only 1 pulse per rev and that was the common reason for this.
As PoolGuy suggests, the minimum you need for a Mini is 6 pulses and 8 is better again.
#15 Ethel
  • 26,761 posts
Posted 06 June 2022 - 10:09 AM
Interesting stuff,
I'm wondering how "digital" it actually is if it needs a minimum number of pulses to register. A speedo not registering under 20 might be tolerable if it's more accurate above that speed, but it has to be useless as an odometer.
