Hi.
I recently had a new rear subframe fitted and at the same time I invested in some new Hilos, new rubber springs and adjustable dampers.
The guy who fitted all this was very good and explained that the Hilos had been adjusted as far 'as he dared go' to get the car level when I picked it up.
This was about 2 months ago.
Driving the car this weekend with three passengers and two dogs on some very potholed lanes I was getting an occasional bang from somewhere under the rear of the car.
I have a theory that what is happening is that the rubbers have now settled, causing some free play to the spring/trumpet unit as the wheel fully drops. The system then bangs when it closes up again. - on hitting a bump or the exit side of a pothole.
So I plan to adjust the ride height up an inch or so or as required.
I haven't yet measured to see where the ride height is at the moment - but it may well be low. Certainly not high from visual inspection. I want to keep it standard.
Excuse my ignorance but is this the likely cause?
- also is there a bump stop to limit downward travel of the hub? or is the damper length controlling this? I see lots of lowered minis around - why don't they have this problem??
Possibly I am totally wrong...any advice appreciated.
