Kyb Gas-A-Just Shocks Question
22 replies to this topic
#1 JDMRoverMini
JDMRoverMini
  • 96 posts
Posted 03 July 2022 - 10:11 AM
Are these just bolt on straight out of the box, or is there something that needs to be done before bolting on?
These shocks:
https://www.minispar...|Back to search
#2 Chris1275gt
Chris1275gt
  • 969 posts
Posted 03 July 2022 - 10:15 AM
They are just bolt on but they altered the ride height on my car so had to adjust the hilos.
#3 sonscar
sonscar
  • 3,062 posts
Posted 03 July 2022 - 10:20 AM
I do not see how a damper can alter the ride height?Not saying it didn't but unless the gas pressure was intense or physically it was stuck or out of travel?Steve..
#4 coopertaz
coopertaz
  • 811 posts
  • Local Club: a-series-magpies
Posted 04 July 2022 - 12:31 PM
just bolt on, a decent unit. Gaz altered height of mine also by 10mm, car is lowered on adjustaride units and damper is lowered unit. damper is not stressed and pulling car down! so left and all ok!
#5 kit352
kit352
  • 244 posts
Posted 10 July 2022 - 12:18 AM
I put the kybs on my car and it raised it a good 10mm or more as well, at least a fingers width. My stock ones were garbage though so probably weren't acting right. They eventually settled in but it took a while. They still sat higher so hi los went in just to even it out.
#6 unburntfuelinthemorning
  • 1,991 posts
Posted 18 July 2022 - 06:36 PM
These shocks:
Remove the old ones first  :shades:
#7 stuart bowes
stuart bowes
  • 2,264 posts
Posted 18 July 2022 - 06:46 PM
nah all the cool cars have two
#8 unburntfuelinthemorning
  • 1,991 posts
Posted 18 July 2022 - 06:48 PM
Nice.  RS200 isn't it?  My dream car when I was ten - didn't realize it wasn't really a normal road car!
#9 Steam
Steam
  • 843 posts
  • Local Club: Victorian Mini Club
Posted 19 July 2022 - 03:25 AM
Rally Group B supercars, what an era that was, Cool cars back then.
#10 R32Egor
R32Egor
  • 313 posts
Posted 19 July 2022 - 07:27 AM
I just put a set on the front and it has raised the car also - have my HILO's at minimum at the mo, hopefully will settle down after some driving.
Anybody have a set on for a while and can tell us anything?
#11 unburntfuelinthemorning
  • 1,991 posts
Posted 19 July 2022 - 10:27 AM
Definitely.  They even made the Metro cool with the 6R4.
#12 gav
gav
  • 700 posts
Posted 19 July 2022 - 11:50 AM
It wont affect the ride height it's probably just where you have jacked the car up and not let it settle again, this happens even if you don't change the dampers...
#13 coopertaz
coopertaz
  • 811 posts
Posted 19 July 2022 - 03:52 PM
yes it can!! and mine did. measured from subframe to road after with standard and gaz, when it didn't clear mot testers rollers on 10inch rims. also drove about with both before measuring to settle
#14 GraemeC
GraemeC
  • 7,446 posts
Posted 19 July 2022 - 04:04 PM
Being a pressurised gas damper rather than oil filled they will add some lift to the suspension. 10mm surprises me, but given the mechanical advantage over the spring due to where each joins the top arm (and more so at the rear) it could be possible.
#15 Cooperman
  • 23,340 posts
Posted 19 July 2022 - 07:38 PM
That takes me back. The company I used to run did a huge amount of design work on the RS200, but we weren't allowed to talk about it back then.
I was offereed a new one for a very low price, but I said the Posche I had then was better! If only!
