Heater Cable
19 replies to this topic
#1 starrider
starrider
  • 431 posts
Posted 11 November 2006 - 04:03 PM
i just replaced my leaky heater valve and discovered my cable is bad as well. how do i take apart from the dash? before i burned my haynes i remember reading i had to drop the heater down to get behind the dash but this seemed a bit extreme. is there an easier way?
cheers
#2 vasi
vasi
  • 897 posts
  • Local Club: Minis 'n' Oatcakes
Posted 11 November 2006 - 04:18 PM
Nope.
Two crossheads to lower the heater, no need to dislocate from rear pegs, although sometimes it can make the job easier.
Then there are two little 5/16" nuts up and behind holding the switch panel on. Remove then the panel comes forward.
Unscrew retaining nut from cable at back of switch panel and the rest is obvious.
The fun part is getting the little nuts back on.
Edited by vasi, 11 November 2006 - 04:22 PM.
#3 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 11 November 2006 - 07:33 PM
as the man says above!! totally simple operation!! 2 screws and the front of the heater drops!! to help access u mite need to remove a couple of the switched to help you!!
#4 starrider
starrider
  • 431 posts
Posted 11 November 2006 - 08:29 PM
cheers mates, sounds like it would be a good idea to go ahead and change the choke cable while i have it apart.
thanks again for the help
#5 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 11 November 2006 - 11:08 PM
I've always wondered just how do you feed it back through the bulkhead? With a bit of string?
As you can see this is a job i've never attempted myself. Yet! :- :proud:
Edited by taffy1967, 11 November 2006 - 11:09 PM.
#6 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 12 November 2006 - 08:05 AM
Nope. Just push it through the hole and then pull it into the engine bay.
Hardest part is getting the 2 bolts which hold the switch facia back on.
#7 Awlred Drives a Quant
  • 145 posts
  • Local Club: Tyred and Exhausted
Posted 12 November 2006 - 08:50 AM
Agreed I bought my mini with one side missing (choke side) so the bolt that protrudes on the z peice ripped through the dash oneday and now theres a nice split in it. Eventually found the nut in the boot and then spent about 2 hours trying to get the bolt through the ruddy hole.
Have fun. I have to do mine today as the choke cable decided it didn't like the carberettor...again >.<
#8 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 12 November 2006 - 01:57 PM
Well nobody uses the heater cable anyway, you could fit two choke cables to your panel, and just swap them over at the carb end when one breaks, means taking the dash apart half as often... :w00t:)
D
#9 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 12 November 2006 - 05:46 PM
Well I do because I like it to blow cold air in the summer and hot in the winter. :w00t:
#10 1984mini25
1984mini25
  • 8,787 posts
Posted 12 November 2006 - 06:12 PM
If it's just the inner cable that’s snapped, you don’t need to replace all of it, as you can get a way with only replacing the broken bit, well I have been (got through 6 choke cables this year>:w00t: )
#11 Awlred Drives a Quant
  • 145 posts
Posted 12 November 2006 - 06:43 PM
No what happened was that it managed to slip out of the bolt without breaking, but I yanked it a bit hard and how its hanging out.
Cold air is in free supply by rolling down your window :w00t:
#12 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 12 November 2006 - 07:10 PM
True but it's a pain in the kneck when your hurtling along the motorway. :w00t:
#13 Mark1275GT
Mark1275GT
  • 487 posts
Posted 14 November 2006 - 12:43 AM
My heater cables broke :w00t:
But never seemed to get cold air in my car ? always hot :w00t:
#14 fikus01
fikus01
  • 1,910 posts
Posted 14 November 2006 - 12:46 AM
i've never had a mini heater that blew cold!! just didnt use the blower in the summer, slid the selector to "off" and opened my window!! tyhe extra circulation cant really hurt can it!
#15 Mark1275GT
Mark1275GT
  • 487 posts
Posted 14 November 2006 - 12:54 AM
When u get a heater cable, does it come with the hole lot, like the fixing bit in the engine bay. as mines break off somewhere. could always get a fan for the summer :w00t:
