Hello Chris,
Great you fixed your problem! Did you clean the stepper before reducing its value with the ACR4?
In a previous post, you told me: "This is the earth for ECT, MAP, IAT and TPS and all these seem to work on your car.", and I forgot to answer. Don't forget I had an error: ("08 throttle potentiometer circuit, logged, sensor output") with the TPS sensor
So, this afternoon, as I had access to a garage with electricity for a few hours and I had nothing else to try on my car right now, I looked into the SJ5 problem.
I removed the air box and searched for the SJ5 solder joint with the help of the very few pictures I found in the German forum.
I removed electric tape of the loom, removed a bit of the split pipe and finally found SJ5!
As I was not sure if the solder was OK or not, I heated it and added a bit of solder. Then I put back the split pipe and electric tape.
Also, during the process I disconnected a few connectors and put some "contact cleaner" on them. It probably doesn't hurt
In case someone else want to find the SJ5 solder joint, I attached a few pics:
- in red, if the SJ5 location (not very precise, but did my best)
- in green, there is a green electric tape on the loom, it may helps to find SJ5
- in blue on the first pic, not related to SJ5, but does anyone know what is this "filter" (?) and the pipe attached to it? Does this pipe seems rigid on your car?
Inside the split pipe, SJ5 was protected with grey electric tape.
Then I went for a quick ride.
After fixing the solder joint, the first time I started the engine, and a few seconds after leaving the garage, my engine had a high idle RPM (more than 1500) and when I pressed the accelerator, it went up to 3000RPM and stayed there. I restarted the engine and everything went back to normal.
Not sure if it's a normal behavior, maybe the calculator was resetting some values?
I didn't get any new problem with the engine, but like the other day, the outside temperature was quite hot (around 33°C). I checked with the ACR4, and I didn't get back the TPS error, so that's cool
I'll try again tomorrow morning, when outside is a bit colder.
I'll also try to go on the highway again, to check if I still have the problem I had this morning (struggling at 2500-3000RPM on 3rd gear).
Have a nice evening,
Olivier
