Headlamp Relay Install
28 replies to this topic
#16 gaspen
gaspen
  • 1,169 posts
Posted 13 July 2022 - 04:21 PM
I keep in mind that Stu  :shifty:
Another idea : I have a similar junction box as on the picture. I bought it 2 years ago but not installed. With this box I wanted to replace the bullet connectors behind the grille. Now I think it would be a nice solution to distribute the lighting wires on the front.
Attached File  VSZEK0095.jpg   42.27K   1 downloads
#17 gaspen
gaspen
  • 1,169 posts
Posted 13 July 2022 - 04:23 PM
Sorry I just found this picture on FB. Pretty overkill  :D
Attached File  278992944_702495924423828_2190798623973131624_n.jpg   90.5K   9 downloads
#18 sonscar
sonscar
  • 3,198 posts
Posted 13 July 2022 - 07:33 PM
Fuses are a good idea,say the headlamp plug melts(it has happened to me)and the live touches the earth?Don't over think it,fit a main and dip relay to each side powered from the solenoid with fuses.Connect the lamps to these relays in the correct order.Use the existing wiring to switch the correct relays.Very simple project.Use your supplier of choice for relays and do not cheap out on the mounts and fuses.Enjoy,Steve..PS it is only wiring in some relays,use google for inspiration.
#19 stuart bowes
stuart bowes
  • 2,530 posts
Posted 13 July 2022 - 09:02 PM
Jesus is that picture of a mini or the space shuttle
#20 bob01b
bob01b
  • 12 posts
  • Local Club: NEMO
Posted 13 July 2022 - 10:46 PM
I am not sure if this link is posted correctly but this post and the next show my relay installation wiring and pic that did not require cuts to the factory wiring.  Note that my Mini is a 63, not a 75.  Hope it helps you.
https://www.theminif...-kit/?p=3673307
#21 gaspen
gaspen
  • 1,169 posts
Posted 14 July 2022 - 04:26 AM
Yes I found your post during my research  :shifty:
What gauge wiring did you use for the high amp circuit ?
#22 bob01b
bob01b
  • 12 posts
  • Local Club: NEMO
Posted 14 July 2022 - 10:55 PM
I used 28 strand wire.  Equivalent to 14 gauge.
#23 stuart bowes
stuart bowes
  • 2,530 posts
Posted 15 July 2022 - 10:16 AM
tidy, nice job
#24 DUF2
DUF2
    Formally known as DUFfi
  • 462 posts
  • Local Club: Whickham & DMC
Posted 16 July 2022 - 04:44 PM
I fitted one of these a couple of years ago
https://www.ebay.co....kp:BFBMnq-c_sBg
it did a good job, it also takes the load off the headlight switch.
well worth the money.
#25 gaspen
gaspen
  • 1,169 posts
Posted 17 July 2022 - 06:41 PM
Thanks, I already have the relay and sockets, now I thinkin about where to install them.
#26 DUF2
DUF2
  • 462 posts
Posted 18 July 2022 - 11:15 AM
Gaspen, mine are on the offside inner wing, the extra 2 relays are for the horn and the spotlight. Please ignore the wiring, I have not wrapped it yet
Attached File  088AEAAE-B681-4DA3-BC9C-83758F1704AB.jpeg   76.29K   1 downloads
#27 gaspen
gaspen
  • 1,169 posts
Posted 28 July 2022 - 06:18 PM
I'm done ! Not the nicest, but it did not burn down  :D
Attached File  IMG_20220728_200814.jpg   58.86K   1 downloads
#28 sonscar
sonscar
  • 3,198 posts
Posted 28 July 2022 - 07:58 PM
Nice,I would probably put insulated sleeves over the bare terminals(unless it was Sunday and I was out of them),Steve..
#29 gaspen
gaspen
  • 1,169 posts
Posted 29 July 2022 - 06:48 AM
Yes it was Sunday :)
