Innocent 1300 Export Engine
2 replies to this topic
#1 MrBounce
MrBounce
  • 2,688 posts
Posted 15 July 2022 - 08:54 PM
What would an Innocenti 1300 Export engine needing a rebuild be worth? A friend has one which has not run for several years and we are not sure what it's worth.
I don't know the full condition of it, so let's assume it is a standard unit needing a full rebuild.
#2 Magneto
Magneto
  • 891 posts
  • Local Club: KC MINI Club
Posted 16 July 2022 - 12:43 AM
Core value on 1275's is usually about $500 here.....
#3 Cooperman
  • 23,569 posts
Posted 05 August 2022 - 09:59 PM
The Inno Export engine is basically a 1300GT block & crank, but with a 510 cam (or equivalent), an 11-stud head, twin Hs2 carbs and a standard 'S' exhaust manifold. Head has 'S' size valves and rocker shaft.
Gearbox has 3.44:1 FDR, but I'm not sure whether the ratios are as the old 'A' or the later standard cars. Gearchange is rod-type, not the remote as the 'S' had.
Basically it's an S spec engine without the special 'S' block & crank. It doesn't have the EN40B crankshaft
Thus its value is the same as an ordinary 1300GT engine in need of a rebuild, say £300 to £400. More if the gearbox is included.
