Front Wheel Alignment Question - Need Help After Today
#16
Posted 01 August 2022 - 04:02 PM
#17
Posted 09 August 2022 - 12:47 PM
Hi all,
Update -
Did the alignment eventually took a few days of playing etc -
Front - -3.5 degs caster, -1.5 camber and 4mm toe out
Rear - -0.5 Camber (didn't want to go further neg after reading Keith Calver's piece about alignment), 3mm toe in - this was a nightmare as I was not using the string method.
I found this on youtube and did this and then perfect -
After all this and driving around it seems good - but i Have a couple of questions still -
Are the front wheels meant to return to center if I let go of the steering wheel with -3.5 deg caster?? - because mine are not really - if i compare to a modern car.
Ride height - Keith Calver says the rear ride height should be around 3/4" (19mm) higher than the front - what ever the front is. I have 20mm higher LH side and 10 mm higher on RH side, If I turn right it feels like there is more grip (harder feedback in the steering wheel) than if I turn left. I am in a LHD mini so my weight I presume has some effect.
So I was wondering if a 10mm difference in ride height is ok or is it better to have the recommended 19mm??
Posted 10 August 2022 - 11:24 PM
Hi Sounds like you are getting this thing sorted.
I measure my heights as per this ( not sure if correct)
Front : _ at rear of front wheel arch near where door panel joins
Rear _ at front of wheel arch near where grease nipple is
( basically similar to jacking points on a modern car)
The difference in side to side height probably needs considering _ if you can take your height measures with you in the drivers seat- (or whatever your most frequent configuration is - eg one passenger etc)
- in my road car my 100kg mass ( all muscle by the way) means it looks one sided when empty but not by much.
From recollection I used 19mm (3/4) sounds right ..... again it seems to work fine for handling and braking.
(((((( Safety advice - please be careful)))))) For your castor ( Which i think is pretty good) when you turn into an average turn and let go of the wheel- the turn will shallow out - in my mini with either 10 inch or 12 inch wheels it is always a bit twitchy from road camber , bumps etc -it isn't the sort of car you can take your hands off the wheel when driving straight ahead ( maybe our roads are more problematic as well ) - so unless you are very concerned about the handling , I would just enjoy the involvement of driving the little beastie.
