Mini Engine 99H213A-H2511 And 12G295 Queries, Any Ideas?
26 replies to this topic
#1 JamesAlexander
JamesAlexander
  • 51 posts
Posted 06 August 2022 - 04:47 PM
Hi folks,
I’ve just acquired this engine but having looked up the number I can’t seem to find any info on it, does anyone have any ideas what it might be from?
99H213A-H2511
It has D-top standard size pistons and a 12g295 head, the head has non standard rockers, does anyone know what they are?
Many thanks in advance for your help!!!
#2 nicklouse
  • 18,601 posts
Posted 06 August 2022 - 05:37 PM
More pics of the engine as a whole.
ps it could well have be a total rebuild but…..
what  is the car registered as?
#3 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 06 August 2022 - 05:53 PM
I think the engine was originally a 998 unit with the Lucas C40 dynamo fitted to a centre change all speed syncro gearbox. Probably circa 1969 and also probably fitted to a van or pick up or a standard 998. Generally the 12G295 head was fitted to the 998 cooper and 1100 MG engines.
#4 JamesAlexander
JamesAlexander
  • 51 posts
Posted 06 August 2022 - 06:06 PM
It was out of a late 60’s mk2 but no idea if it was the original engine, the guy said it had had an alternator conversion but had very little info, it has a 22G1128 remote gearbox on it...
plus oil cooler and not a mini rad, a but bigger by the looks of it...
Edited by JamesAlexander, 06 August 2022 - 06:08 PM.
#5 JamesAlexander
JamesAlexander
  • 51 posts
Posted 06 August 2022 - 06:19 PM
The bores have slight wear at the tops, not great but you can feel slight ridges, is this rebore territory or will I get away with it?!
#6 weef
weef
  • 493 posts
Posted 06 August 2022 - 06:22 PM
The use of "D" top pistons on a 998cc negates the need to skim a 12G965 cylinder, a nominal 2.75" as standard, still maintaining a usable compression ratio.
#7 nicklouse
  • 18,601 posts
Posted 06 August 2022 - 07:06 PM
More pics of the engine out of the car?
gearbox remote connection.
front plate under the alternator.
#8 JamesAlexander
JamesAlexander
  • 51 posts
Posted 06 August 2022 - 07:21 PM
Here are some more pics!
#9 Cooperman
  • 23,294 posts
Posted 06 August 2022 - 10:12 PM
Looks like a 998 Cooper engine and gearbox. The D-top pistons are the giveaway.
Unfortunately, if a re-bore is necessary, the D-tops are NLA so you will end up with flat-tops which will mean the head will need to be skimmed.
The rockers are Cooper 'S' type and the original dynamo has been replaced with an alternator.
That jas the basis to be a nice engine.
#10 JamesAlexander
JamesAlexander
  • 51 posts
Posted 07 August 2022 - 09:50 AM
Thanks Cooperman, I still don’t understand the engine number, it doesn’t seem to in the guessworks list..?
The 12g295 head has been skimmed to 2.69inch or 68.3mm too, going to get the cam out now to check what it is.
#11 nicklouse
  • 18,601 posts
Posted 07 August 2022 - 10:00 AM
Re the engine number. The Guessworks decoder does not include all the variants that use the A series and does not include the engine numbers for non UK. built engines. Hence the request for more pictures. It does not look like it has come from a variant and the car does look like a UK built one. But the number is included in a list I have but just as a 998 1970 on…..
#12 JamesAlexander
JamesAlexander
  • 51 posts
Posted 07 August 2022 - 12:09 PM
Ah ok Nicklouse, so it might be a standard block with Cooper pistons?
I have just removed the cam, no markings on it but one raised ridge at the back of the engine, does anyone know what it might be from? Is it just the original cam perhaps?
Edited by JamesAlexander, 07 August 2022 - 12:12 PM.
#13 nicklouse
  • 18,601 posts
Posted 07 August 2022 - 12:24 PM
Nope. It might be the engine number that was fitted to the car.
and nothing to do with what the engine actually is. The scrivits don’t look original.
cam info https://www.theminif...identification/
#14 JamesAlexander
JamesAlexander
  • 51 posts
Posted 07 August 2022 - 12:42 PM
Yes true, they do look off!
#15 timmy850
timmy850
  • 3,340 posts
  • Local Club: MITG
Posted 07 August 2022 - 01:16 PM
So:
99 - 998cc
H - transverse engine
213 - means codes Ub (Lucas C40 Dynamo) and We (Centre change all synchromesh)
A - no additional features
H - high compression
I can't say what car it came out of, but might give you an idea. The 4 synchro gearbox was introduced in late 1968 & the centre gear change would suggest a base model saloon or commercial.
