Tap And Die Set
31 replies to this topic
#1 Gaz66
Gaz66
  • 950 posts
Posted 14 August 2022 - 09:28 PM
Any recommendations for a decent tap and die set? A Metric and imperial set would be ideal.
It seems there are lots available on the net but the cheap prices are putting me off...they cant be any good or are they.
Are they all much the same or will the cheap ones cut one thread then be useless?
Its a tapping minefield out there!
#2 Icey
Icey
  • 1,551 posts
Posted 14 August 2022 - 10:22 PM
I buy most of my machine tools (including taps/dies) from arceurotrade.co.uk they tend to only do metric stuff though.
A brand I stubbled into while buying some odd imperial sizes was Volkel, they’re really nicely made but not cheap. I’ve been back-filling my set with them as the cheap ones break/wear out.
Also remember that you really need matching drill sizes to go with the threading gear. Getting decent imperial drill sets seems to be getting tricky. I recently bought a set from Presto which is pretty good but not the cheapest (£130 if memory serves), there just didn’t seem to be many options out there.
#3 nicklouse
  • 18,657 posts
Posted 14 August 2022 - 10:28 PM
This might help
https://www.theminif...l=imperial taps
#4 Gaz66
Gaz66
  • 950 posts
Posted 14 August 2022 - 10:48 PM
Is it better to buy individually as I need them I wonder.
Theres a lot of bad reviews especially concerning the wrenches
#5 Spider
  • 15,038 posts
Posted 15 August 2022 - 01:00 AM
It depends if you think you'll have other uses for them.
For a Mini, if you bought;-
1/4" UNF
5/16" UNF
5/16" UNC
3/8" UNF
That will cover probably 90% of the car.
#6 MatthewsDad
MatthewsDad
  • 819 posts
Posted 15 August 2022 - 07:51 AM
Machine Mart do an affordable, reasonable quality imperial set that will cover most situations
#7 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 15 August 2022 - 08:20 AM
I bought this one:
BGS
Quite happy with it, although I can see it's not the best quality, but for cleaning some threads OK enough until now :). Let's see when I will have cut 10 new threads.
#8 mini13
mini13
  • 3,811 posts
Posted 15 August 2022 - 09:30 AM
I tend to buy tap sets as I need them, then you can get the sets with three taps in, taper, plug and bottom.
#9 ac427
ac427
  • 679 posts
Posted 15 August 2022 - 10:05 AM
Did you mean taper, second and bottom?
#10 ac427
ac427
  • 679 posts
Posted 15 August 2022 - 10:11 AM
Have a look at the link below, Tap and Die have been going for years, since 1978.
http://www.tapdie.com/ and http://www.tapdie.co...s_products.html
Probably best to give them a call since they are very helpful and stock every thread standard known to Man.
Edited by ac427, 15 August 2022 - 10:18 AM.
#11 GraemeC
GraemeC
  • 7,440 posts
Posted 15 August 2022 - 10:28 AM
For cleaning threads I suggest using thread chasers rather than a tap or die.
A tap or die could cut more away (especially where the originally thread was rolled) and in some cases this can cause the threadform to be under/over size.
Thread chasers are far more forgiving and can generally be used much quicker and safer.
I would only use a tap or die to rescue a damaged thread, and even then I'd question whether a new fastener (or thread insert) would be a better repair.
#12 mini13
mini13
  • 3,811 posts
Posted 15 August 2022 - 12:11 PM
Yep, second is better terminology,  generally in my experience plug refers to the second, but I have seen plug refering to the bottom tap, dunno if thats a UK/US thing or what.
#13 PoolGuy
PoolGuy
  • 854 posts
Posted 15 August 2022 - 12:40 PM
Personally I buy them separately, and use Starrett handles which I find superb. I've used Tracy Tools and occasionally ebay for the actual taps depending on how often I think they'll be used.
#14 ac427
ac427
  • 679 posts
Posted 15 August 2022 - 01:13 PM
Ah yes it could be.  I have always known plug as the last tap in a set for finishing or blind holes.
Does the tool make "General" still exist in the States?
I always liked their tools.
Edited by ac427, 15 August 2022 - 01:16 PM.
#15 Spider
  • 15,038 posts
Posted 15 August 2022 - 07:41 PM
I did also mean to include in my post above, but HSS - High Speed Steel - Taps and Dies, though are tougher are less likely to break. These are usually bight in appearance. The types that are Black are usually (a) Carbon Steel and often brittle, you'll end up with a $1 tap broken off in a $1000 part.
Agree too with Graeme's advice on buying thread chasers.
