Tap And Die Set
31 replies to this topic
#31 nicklouse
  • 18,657 posts
Posted 16 August 2022 - 09:08 PM
Gas,
thought I would add some pictures and info.
what I started out with some time back in the 80s
Then I bought some sets to do what I needed.
If you look carefully you can see rings on the taps.
these identify the use. First/second/last
finally
two M14 taps with one ring.
but one is for use in a machine and cuts to a different spec to the one ring hand tap.
the temp sender would not go into the hole I cut with the longer of the two. But would after running the hand one through.
someone on here will be able to explain the difference I don’t have the info.
#32 stoneface
stoneface
  • 392 posts
Posted 16 August 2022 - 10:25 PM
If you want more info have a read here. https://www.mscdirec...m/basicsof/taps
Like you can have tolerances for limits and fits for shafts/holes you can have the same for taps, where depending on the thread class you can make them tighter or looser.
You can also use a different class of tap to cut a thread slightly over size to allow for the addition of plating.
There's more to it than many think when selecting taps and dies for precision engineering.
