Anti Run-On Valve, Where To Buy
20 replies to this topic
#1 GermanMoreno
GermanMoreno
  • 206 posts
  • Local Club: Mainly Minis Montreal
Posted 22 August 2022 - 08:59 PM
Hello, does anyone know where I can buy an anti run-on valve online at a reasonable price? , 91 Cooper.
ADU9535  or  MAV10021
#2 mab01uk
mab01uk
  • 12,549 posts
Posted 22 August 2022 - 10:45 PM
Anti run on valve for various vehicles including Classic Mini - Part no. ADU9535
https://www.ebay.co....tm/183742018613
Edited by mab01uk, 22 August 2022 - 10:45 PM.
#3 GermanMoreno
GermanMoreno
  • 206 posts
Posted 23 August 2022 - 01:55 PM
that's a hefty price!
#4 mab01uk
mab01uk
  • 12,549 posts
Posted 23 August 2022 - 03:17 PM
Seems to be the going rate for the valve now unless you can find a good used valve.
#5 sonscar
sonscar
  • 3,051 posts
Posted 23 August 2022 - 05:58 PM
Does your engine actually run on?Paupers anti run on valve;apply full throttle just after turning key off,some practice required.Always worked on the junk I ran,Steve..
#6 cal844
cal844
  • 9,648 posts
  • Local Club: TFMOC
Posted 23 August 2022 - 06:19 PM
I always put my minis into 1st gear, handbrake on then kill the engine with the key... If it runs on just lift the clutch
#7 floormanager
floormanager
  • 719 posts
  • Local Club: Mini Club Sussex
Posted 23 August 2022 - 07:16 PM
I've got a couple of used ones if you want one.
#8 gazza82
gazza82
  • 3,020 posts
  • Local Club: TMF+
Posted 23 August 2022 - 07:21 PM
When my A-series ran on it was due to too weak fuel mix and in dire need of a de-coke!
It can also be the wrong plugs.
Edited by gazza82, 23 August 2022 - 07:21 PM.
#9 Cooperman
  • 23,328 posts
Posted 23 August 2022 - 08:07 PM
That is exactly what I have always done. Never had any problems.
#10 GermanMoreno
GermanMoreno
  • 206 posts
Posted 23 August 2022 - 08:13 PM
Sure thing!
#11 GermanMoreno
GermanMoreno
  • 206 posts
Weak meaning lean, or weak meaning bad mixture?
#12 GermanMoreno
GermanMoreno
  • 206 posts
Posted 23 August 2022 - 08:17 PM
After getting the timing to spec, its almost gone, there is a very minimal amount of it, like a split second, and it happens only on hot days! its weird.
I unplugged my current anti run on valve for test purposes, and the car had a hard time starting and staying at idle, which tells me the valve works.
I plugged it back and the car went back to normal.
#13 gazza82
gazza82
  • 3,020 posts
  • Local Club: TMF+
Posted 23 August 2022 - 10:03 PM
Weak mixture ...
#14 coopertaz
coopertaz
  • 807 posts
  • Local Club: a-series-magpies
Posted 24 August 2022 - 09:55 AM
never knew these valves were that much now!!
#15 Ethel
  • 26,088 posts
Posted 24 August 2022 - 10:41 AM
It was normal on the high compression A+ engines of the 80's. The valve just allows more air in to the manifold to stop the engine sucking fuel, you could do the same with a different valve, unless you want one for authenticity. An alternative tactic is to seal the float chamber venting off.
