Anti Run-On Valve, Where To Buy
20 replies to this topic
#16 mab01uk
mab01uk
  • 12,551 posts
Posted 24 August 2022 - 10:49 AM
As said it was normal on the high compression A+ engines of the 80's and early 90's, especially with carbs adjusted to meet MOT emissions regs, which is why many Metros and carb Rover Mini Coopers had anti-run-on valves fitted as standard from the factory.
Allowing an engine to run on can cause damage and BL/Rover could not put in the handbook for the average motorist:-
"put your Mini into 1st gear, handbrake on then kill the engine with the key... If it runs on just lift the clutch."  :lol:
Edited by mab01uk, 24 August 2022 - 11:18 AM.
#17 andyapanel
andyapanel
  • 626 posts
Posted 25 August 2022 - 08:03 AM
Put a rubber glove finger over it and test to see if it is still operating. I was suspicious of the one on my RSP last year and was a bit concerned about the price. I traced the fault elsewhere.
If it fails, it will fail open, and the engine will probably never start.
Check the idle screw on the carb: mine had readjusted itself
Good luck
#18 Ethel
  • 26,088 posts
Posted 25 August 2022 - 08:14 AM
I've got a drawer full of rubber glove fingers from waterproofing distributors. Thanks, now I have a use for them  :D
#19 GermanMoreno
GermanMoreno
  • 206 posts
  • Local Club: Mainly Minis Montreal
Posted 25 August 2022 - 02:26 PM
What I did was to unplug the power feed to the valve.
Indeed the car had a very hard time starting and running at idle.
Good luck
#20 floormanager
floormanager
  • 719 posts
  • Local Club: Mini Club Sussex
Posted 28 August 2022 - 07:52 AM
Hi, Turns out I have three.  One has the anti run on valve in a pipe, the other two have a filter on them.
Attached File  anti-run on.jpg   38.93K   4 downloads
#21 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 31 August 2022 - 08:29 AM
Raising the clutch in top gear to reduce rpm then turning off is the most common way. Don't use 1st gear.
However, for a fraction of the price of an anti run-on valve, get ebay item no. 284623854979 which is a NORMALLY OPEN solenoid valve, a couple of fittings and hose, small amount of wiring from the switched live at fuse box and you're sorted £20.00 should cover it.  .
Edited by Pigeonto, 31 August 2022 - 08:43 AM.
