that suggests that either the chambers have been taken out a bit already, or the pistons were a fair distance from the deck. ( or a mix of both)
Personally i don't like running pistons down the bore for squish reason,s I always have the block skimmed to bring them up to about 5 thou down, leaving enough for a clean up skim if its ever needed. also Im not a fan of de comp plates for the same reason.
I have the engine apart now and yeah the pistons are far down from the deck I measured 1mm. I have not measured the chamber volume yet.
