Twin Su Carbs, Filters Or Ram Pipes ?
Posted 02 September 2022 - 01:52 PM
Have kandn filters but fancy Rams
Whats thoughts
Posted 02 September 2022 - 05:18 PM
You can get ram pipes that fit inside the K&N
Posted 02 September 2022 - 06:16 PM
Both.
Posted 02 September 2022 - 07:16 PM
David Vizard wrote some interesting articles on the increased engine and bore wear when running an engine without any filters....his tests usually proved K&N filters were the best with little if any loss of power. As said above you can also have both....
Posted 02 September 2022 - 07:36 PM
Posted 02 September 2022 - 07:49 PM
Posted 02 September 2022 - 07:55 PM
Edited by stuart bowes, 02 September 2022 - 08:00 PM.
Posted 02 September 2022 - 08:33 PM
I'd highly recommend a set of stub stacks inside a modern foam filter setup. My own car runs a pair of HS4s fitted with a RAMAIR quick release foam filter, and a pair of K&N stub stacks easily fit inside and act as internal ram pipes. This setup performs well and sounds brilliant, and I'm sure you could fit the same stub stacks inside the cone-type K&N filters if you preferred to go down that route. MED have a nice range available. https://www.med-engi...es/stub-stacksĀ
Edited by MiniCarJack, 02 September 2022 - 08:35 PM.
Posted 02 September 2022 - 09:21 PM
You'll struggle to get MED stub stacks to fit in a K&N cone filter
Posted 03 September 2022 - 04:17 AM
More air flow means more dust. Dust kills engines.
Posted 03 September 2022 - 04:41 AM
Or you can get more airflow by increasing the filter area
I've also seen a few variations on this idea, with ram pipes and KN cone filters around them
https://mk1-forum.ne...28477&start=480
Edited by timmy850, 03 September 2022 - 04:41 AM.
Posted 03 September 2022 - 06:35 AM
Why would anyone run an engine without an air filter have I missed something or did I misunderstand the question
Simple, aesthetics.
Posted 03 September 2022 - 07:24 AM
Posted 03 September 2022 - 08:01 AM
These MED filters and stacks look interesting https://www.med-engi...ub-stack-system
The rounded stacks look more effective in guiding the air into the carb throat than the little K&N type stacks.
Posted 03 September 2022 - 08:09 AM
Simple, aesthetics.
So. it 'looks cool' to destroy the engine even though 99% of the time the bonnet is shut and no-one will see it
take it off when it's on display and put it back on when you drive it then surely
Edited by stuart bowes, 03 September 2022 - 08:10 AM.
