Drilled Thermostats
Best Answer Spider , 17 September 2022 - 12:45 AM
Even without holes, when the Thermostat is closed, the warmer coolant will always rise to the higher parts of the coolant circuit - right where the Thermostat is.
If they were meant to have holes, they would be available that way.
Go to the full post
19 replies to this topic
#1 croc7
croc7
  • 820 posts
Posted 14 September 2022 - 06:06 AM
What is the desired result of drilling 4-6 1/8” diameter holes around the circumference of the thermostat? Doesn’t that defeat it’s purpose to regulate coolant temperature?
#2 nev100
nev100
  • Just Joined
  • 143 posts
Posted 14 September 2022 - 06:16 AM
I think it allows the flow of water when the thermostat is closed as the pump is still spinning..
#3 nicklouse
  • 18,743 posts
Posted 14 September 2022 - 06:40 AM
Nothing. All it does is increase the time it takes for the engine to get up to temp.
if you are using the correct one with the bleed valve in it with the wobbley thing in the rim there is no need to put any more holes is it as it will work as desired when it warms up.
#4 imack
imack
  • 2,222 posts
Posted 14 September 2022 - 06:47 AM
Engine never reaches operating temperature in cooler conditions with drilled stat.
#5 Steam
Steam
  • 848 posts
  • Local Club: Victorian Mini Club
Posted 14 September 2022 - 07:15 AM
It was a fix for engines minus the small bypass hose at the back of the head to block. To allow some flow before the tstat opens.
#6 sonscar
sonscar
  • 3,077 posts
Posted 14 September 2022 - 09:26 AM
So,Leyland made millions of Minis and did not do it?anecdotal evidence says do it?Which to believe eh?Just an older gents thoughts,Steve..
#7 mab01uk
mab01uk
  • 12,605 posts
Posted 14 September 2022 - 09:42 AM
As said by Steam above i think this was mainly advised for Mini owners who fitted a Metro/late Mini engine/head that had the small by-pass hose connections blanked off and did not want to modify the head and water pump to fit one.
If the thermostat is completely removed for any reason then a thermostat blanking sleeve should be fitted as below.
"Removal of the thermostat helps to reduce engine temperature, however a thermostat blanking sleeve should be fitted to maintain correct coolant circulation to the entire head. Failure to do so will cause overheating around #3 and 4 combustion chambers, with obviously disastrous results. When the blanking sleeve is used it is also necessary to blank off the by-pass hose (not found on late heads) between the head and water pump."
https://www.minispar...sic/11G176.aspx
Edited by mab01uk, 14 September 2022 - 09:49 AM.
#8 Steve220
Steve220
  • 5,077 posts
  • Local Club: BMC
Posted 14 September 2022 - 10:40 AM
Not sure on drilling loads of holes, but on the MPi, if it doesn't have a hole and a jiggle pin, then I always drill a 2mm hole to aid air bleeding as they're notoriously bad.
#9 Spider
  • 15,225 posts
Posted 14 September 2022 - 10:51 AM
I've always blocked off the By-pass and never drilled the Thermostat. Let it do it's job.
#10 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 14 September 2022 - 11:32 AM
It's an old fix for a problem that never existed. If you've fitted the correct stat with the bleed hole and pin in it you won't have a problem.
#11 andyapanel
andyapanel
  • 627 posts
Posted 14 September 2022 - 11:43 AM
I have not seen a new thermostat with a bleed toggle in it for ages.
#12 PoolGuy
PoolGuy
  • 862 posts
Posted 14 September 2022 - 12:34 PM
https://www.minispar...sic/GTS106.aspx
#13 Lplus
Lplus
  • 918 posts
Posted 14 September 2022 - 01:02 PM
The joke is that the bleed hole and pin/ball shuts when the pump is in operation.  It only opens when the engines stops, presumably to let air pass up to the rad top.
The explanation given for the small holes was to ensure there is a flow of hot water past the thermostat enabling it to get hot and open as the water heats up.  It also ensures there is some flow within the head to prevent hotspots forming.  The open heater valve does allow flow in the head, but not ensure the thermostat gets a flow past it.  The MPi set up ensures water passes the thermostat by having the heater take off under the thermostat.
As to whether the engine reaches operating temp, well yes, for sure it does, at least mine does.
The original design with the bypass to shortcut the radiator ensured the thermosat had water flowing past it, then blocked the bypass with a shield when the thermostat opened.  That type or thermostat is long gone, though NOS can be found sometimes.
eg http://coventryautoc...&product_id=268
#14 mab01uk
mab01uk
  • 12,605 posts
Posted 14 September 2022 - 04:43 PM
Quote from the Minispares link above:-
"It is possible to run thermostats with the troublesome bypass hose blanked off by drilling 4-6 holes 1/8" in size around the periphery of the thermostat."
#15 Lplus
Lplus
  • 918 posts
Posted 14 September 2022 - 07:03 PM
I've use 3 X 3mm holes successfully.   On engines with the bypass I do wonder if a restrictor in the bypass might be beneficial, given the lack of shield on the thermostat to close the bypass off.
