Drilled Thermostats
Best Answer Spider , 17 September 2022 - 12:45 AM
Even without holes, when the Thermostat is closed, the warmer coolant will always rise to the higher parts of the coolant circuit - right where the Thermostat is.
If they were meant to have holes, they would be available that way.
Go to the full post
19 replies to this topic
#16 coopertaz
coopertaz
  • 816 posts
  • Local Club: a-series-magpies
Posted 16 September 2022 - 10:37 AM
surely the drilling of holes is only if the bypass is blocked off to keep a small flow over the thermostat bulb.
#17 Lplus
Lplus
  • 918 posts
Posted 16 September 2022 - 06:59 PM
Yep, that's correct.  One of my cars has an A+ 1275 with no bypass and three holes drilled in the thermostat plate, the other mini is an 1100 with a bypass and an undrilled thermostat.
#18 ThermalEvent
ThermalEvent
  • 123 posts
  • Local Club: n/a
Posted 16 September 2022 - 07:15 PM
I drilled my thermostat as per Minispares recommendations and it took 15-20mins to get up to temp. Installed one without and now its 5 mins... I won't ever drill one again and I have no bypass.
#19 Spider
  • 15,226 posts
Posted 17 September 2022 - 12:45 AM   Best Answer
#20 nicklouse
  • 18,743 posts
Posted 17 September 2022 - 05:45 AM
Again not needed.
