Clubman Custom Inner Wings
4 replies to this topic
#1 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 08 November 2022 - 02:57 PM
Hi everyone.
I’ve started a project to build my own clubman inner wings, partly because of the huge cost of genuine items and the lack of a pattern alternative. Also because I don’t want most of the openings in them because I’m planning to run a front radiator and hidden wiring.
Ive done a couple of YouTube videos on my progress. If anyone has any advice or has done anything similar. I’d appreciate the advice.
Classic Mini - Clubman Front End - Chapter 9
https://youtu.be/MKOJUWvrtho
Edited by fikus01, 08 November 2022 - 02:58 PM.
#2 fikus01
fikus01
  • 1,910 posts
Posted 08 November 2022 - 02:58 PM
Part 2 is here and that’s my current progress level.
Classic Mini - Clubman Front End - Chapter 9 1/2
https://youtu.be/_REY0zetX9w
#3 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 08 November 2022 - 10:19 PM
I made a custom nearside inner wing for my Clubman for exactly the same reason. It's shape lends itself to bend relatively easily into a mirror image of the offside one. I actually used quite a heavy gauge galv sheet that I scranned but would've saved a tonne of heartache if I'd bought the correct gauge of mild steel! I made the vertical section out of one part and the top flat bit that joins to the outer wing out of another bit then butt welded the two together but with hindsight I should've made it all out of the one large sheet then I would've had to put in a small wedge shaped part on the top. There should be a few photos on my build thread "My Fixerupper" regarding that part of the build.
#4 fikus01
fikus01
  • 1,910 posts
Posted 09 November 2022 - 05:41 PM
Awsome thanks. I’ll look it up.
#5 fikus01
fikus01
  • 1,910 posts
Posted 09 November 2022 - 06:17 PM
Just been through the build thread. That’s a brilliant bit of imagery for me. Thank you very much. If you don’t mind I’ll mention your build thread on my next video.
