Primary Gear Tolerance
28 replies to this topic
#16 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 20 November 2022 - 04:54 PM
The primary gear oil seal need to not leak
#17 Spider
  • 15,142 posts
Posted 20 November 2022 - 06:31 PM
Ok now I know the tolerance but how should I measure it ?  O_O
I've been giving this some thought since you posted the question and really, the only way I can think of is to check it in a lathe, clock in the Primary Gear in a 4 jaw chuck, then check the run out on the bushes.
While the factory tolerances on the Primary Gear may have been that tight, keep in mind here, the fitting clearance is up to 0.0045" (0.114 mm), so in operation, the Primary Gear can have 0.0045" run out and still be fine. I've removed worn gears that have had up to 0.014" Running Clearance and not leaked on the seal.
If you have a dial gauge, you could fit up your Primary Gear on to the Crankshaft Tail and then measure the Run Out to the Seal Face on the Primary Gear. Not the best or easiest way to measure it, but it'll at least give you a guide.
I always found the new A Primary Gears fine out of the box, but the late new Rover boxed A+ Primary Gears while concentric, the bushes were nearly always out of Spec out of the box, they were bad.
#18 gaspen
gaspen
  • 980 posts
Posted 20 November 2022 - 07:14 PM
In summary : I am not really need to worry about these gears.
#19 Spider
  • 15,142 posts
Posted 20 November 2022 - 07:46 PM
I'd suggest checking the Bush to Crank Clearance, to make sure that's within spec (0.003 - 0.0045" or 0.075 - 0.11 mm) but otherwise, you should be fine.
#20 gaspen
gaspen
  • 980 posts
Posted 29 December 2022 - 07:42 AM
Well I replaced the p/g last weekend - or i just wanted it. I've checked the endfloat with the NOS p/g in place with the thickest thrut washer and it was 0.2 mm (~0.008") which is out of the tolerance. Then I measure the total length of the p/g and it was ~72.05 mm. So it was not a good deal  :shy: Fortunatley I have an other one within the tolerances.
Attached File  EUuv0nt (1).jpeg   91.5K   1 downloads
Anyway : SKF produce self-lubricated bearings. There is a suitable size to machine for the primary gear. Do you think it will be gooed enough for Mini ?
https://www.skf.com/...PSMF 354525 A51
#21 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 29 December 2022 - 10:27 AM
Don’t waste your time, simply make an oversize thrust washer.
Ac
#22 gaspen
gaspen
  • 980 posts
Posted 29 December 2022 - 10:44 AM
Ac
I see but I don not have any machine
#23 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 29 December 2022 - 12:16 PM
What size do you need? And what size engine is it?
Ac
Edited by ACDodd, 29 December 2022 - 12:18 PM.
#24 gaspen
gaspen
  • 980 posts
Posted 29 December 2022 - 12:50 PM
Ac
It is a basic 998cc. The endfloat with 0.118" washer is ~0.2mm. I guess 3.1mm (0.122") would be fine. But I live in Hungary
#25 Spider
  • 15,142 posts
Posted 29 December 2022 - 05:55 PM
You can get a thrust washer that's in the 0.120 - 0.122" range;-
and also a backing ring that's 0.002" thicker than standard;-
http://www.minispare.../search/classic/primary%20gear.aspx|Back%20to%20search
I'd say between these, you should get where you need to be. If you can't, drop me a PM and I'll make you a thrust washer to suit.
In regards to the SKF material, I couldn't pull up the specs on it, however I'm sure the rated surface speed will be well below that needed. I have been offered all kinds of exotic replacement materials over the years, but all fall short on this one important specification.
Frankly, after seeing the expensive damage cheap or 'she'll be right' type materials do to, I'm done with considering anything other than genuine Deva material.
#26 gaspen
gaspen
  • 980 posts
Posted 29 December 2022 - 08:03 PM
Thanks! How I couldn't find the 0.122" washers and the thicker ring ?!  O_O
#27 gaspen
gaspen
  • 980 posts
Posted 04 January 2023 - 08:39 AM
So I "cooked" the gear in hot oil. But after finish the surface of the bushes became dark-greyish. I could remove it with a fine abrasive sponge only.
Is it normal?
#28 Spider
  • 15,142 posts
Posted 04 January 2023 - 05:55 PM
Is it normal?
Those sponges usually have Carborundum impregnated in to them and as you use them, these particles literally fall out and if working something soft, can get impregnated in to the softer material. These bushes I would class as being on the soft side, hopefully you might get it all out with cleaning.
I'd suggest cleaning the gear quite thoroughly in brake cleaner or something light to remove any abrasive that might be left from the sponge. Maybe heat the gear again in oil and clean again while hot, just don't burn yourself.
Any discolouration would have come from additives in the oil and would be OK to leave. If you do a hot oil soak,at the end of the heating (4 + hrs), I remove the gear and let it stand in a try for the excess oil to run off and let the gear cool to room temperature. Usually I do this days ahead of when I need it, so I just bag it up in a clean bag until it's needed. I don't degrease or otherwise clean the gear at this point, but leave it dripping in oil. When fitting up, give the tail of the crank a smear of oil, fit the gear up and then the Flywheel Cover. It is at this point I carefully clean the splines of the gear of excess oil.
#29 gaspen
gaspen
  • 980 posts
Posted 05 January 2023 - 09:40 PM
Is it normal?
Thanks again ! I'll follow your lesson  :proud:
