Led Sealed Beams, No Drl Only
electrical
Best Answer sonscar , 28 November 2022 - 04:32 PM
Is your car equipped with the dim/dip system?what you describe is a feature of this system,Steve.. Go to the full post
7 replies to this topic
#1 STC19
STC19
  • 22 posts
Posted 28 November 2022 - 02:05 PM
Hello forum!
I hope everyone is well.
I have recently installed some LED sealed-beams on my '95 SPI mini, mainly so I can actually see where i am going in the dark. ( I will change them back to stock when the days are longer :proud: ).
The units in question can be found here: https://tinyurl.com/mt5jk4c2
When I put my light switch in the first position (side lights), the low beams also come on, all be it slightly dimmer. Ideally i would like only the outer halo to illuminate.
Has anyone come across this 'issue'?
I do not have my indicators connected up to the LED Halo, just the side light circuit.
Any help/advice is much appreciated. :proud:
Many thanks,
Sam
Edited by STC19, 28 November 2022 - 04:13 PM.
#2 PoolGuy
PoolGuy
  • 848 posts
Posted 28 November 2022 - 02:16 PM
I can't help you with the wiring but I'd suggest that you get a garage to pop them on their MOT beam tester gadget, a friend bought the same lights recently and the beam pattern was beyond awful, he sent them back.
Yes, that's two hot spots from one dip beam light.
Edited by PoolGuy, 28 November 2022 - 02:18 PM.
#3 sonscar
sonscar
  • 3,000 posts
Posted 28 November 2022 - 04:32 PM   Best Answer
#4 Richard_
Richard_
  • 239 posts
  • Local Club: ISMOC
Posted 28 November 2022 - 08:59 PM
Yes I agree with sonscar. The dim/dip hardware (relay and ballast resistor) is located behind the rad. Quite easy to disable.
#5 STC19
STC19
  • 22 posts
Posted 28 November 2022 - 10:24 PM
Ah i see,
I believe that it does, yes
I shall have a look at the weekend
thanks for the advice.  :-)
Sam
#6 STC19
STC19
  • 22 posts
Posted 04 December 2022 - 09:35 PM
Evening Forum!
I hope you have all had good weekends.
I have tried the advice above this eveing and it worked!
I unplugged the resitor (and isolated the ends) and bingo, the 'issue' is solved.  :proud:
Now when light switch in the side-light position, only the LED halo comes on.
Many thanks sonscar and Richard_,
Sam
Edited by STC19, 04 December 2022 - 09:37 PM.
#7 coopertaz
coopertaz
  • 796 posts
  • Local Club: a-series-magpies
Posted 09 December 2022 - 01:02 PM
is beam pattern on these as crap as poolguy says? was considering these for other halfs min.
#8 STC19
STC19
  • 22 posts
Posted 10 December 2022 - 11:50 PM
Hello,
They seem alright to me, miles brighter then the halogens before. Pattern seems to be similar.
I shall  take a photo tomorrow evening when it is dark.
I am going to take them to an MOT center in the next week or so to align them, so will ask them to check on their device.
