a/f or metric
bigb1970
, Nov 13 2006 10:59 PM
8 replies to this topic
Posted 13 November 2006 - 10:59 PM
Are all minis a/f spanner sizer or are later ones metric?
Posted 13 November 2006 - 11:01 PM
All imperial sizes, right up to the last cars. You may find a couple of metric fixings on some of the electrics but all mechanical items will be imperial.
Posted 13 November 2006 - 11:03 PM
i've found everything on minis!! later ones have more metric i think!! having a tool kit that comprises of both is always a plus!!
Posted 13 November 2006 - 11:04 PM
Just got job in mini garage only got metric toolsAll imperial sizes, right up to the last cars. You may find a couple of metric fixings on some of the electrics but all mechanical items will be imperial.
Posted 13 November 2006 - 11:13 PM
3/8 is near as nuts half way between 9 and 10mm
7/16 is 11mm
1/2 is slightly smaller than 13mm
9/16 is a little bigger than 14mm
5/8 is awkward 16mm sometimes covers it!!
11/16 is in the 17 - 18mm region
3/4 is 19mm
7/8 is 22mm
15/16 is 24mm
hope that helps!!
what have you got to do to it?
7/16 is 11mm
3/4 is 19mm
7/8 is 22mm
15/16 is 24mm
hope that helps!!
Posted 14 November 2006 - 10:55 AM
As standard most things are imperial, but minis have been around so long now that as fikus says, any kind of nut or bolt could have been put on there!
Posted 14 November 2006 - 01:41 PM
I'm sorry, but a mini specialist with only metric tools does not bode well..... That just shows a complete lack of consideration for customer vehicles, and mechanics...
Up until a couple of months ago, I didn't have a metric tool in box.... actually that's a lie, 1 30mm socket for the verto flywheel bolt.
What I am coming across more often tho' is where metric bolts have been used to replace UNC bolts, which is a right pain in the ****, especially as I dont have a spanner, and it goof's up the threads.
Posted 14 November 2006 - 02:07 PM
I think he is saying that he has got a job in a mini garage and he only owns metric tools and wants to know what imperial tools he should buy?
Posted 14 November 2006 - 02:08 PM
Having used metric tools on imperial bolts, all I can say is dont ! Get a decent set of both and you will be fine. Most socket sets come with a selection of the two anyway
