Pick Up Bonnet Hinges
Posted 18 January 2023 - 08:44 PM
I talked to MS and they said yep had a few phone calls about them. It seems there was a variation of the hinges they didn't know about so they don't fit.
Anyway I'm getting bored with taking the wipers off to open the bonnet and then I scratched the paint putting them back on when I slipped🙈
So I want to put some normal ones back on. My old ones appear to be the same shape as clubman hinges? Slightly more rounded than the normal 1980-on hinges
Pictures on minispares aren't great so on minisport mine look like SMB 182/3
whereas I would have thought they should be more like BMP0348.
Any insights please?
Posted 18 January 2023 - 11:20 PM
Not aware of there being any special bonnets or hinges for the pickups.
what year is yours?
Posted 19 January 2023 - 12:49 AM
Posted 19 January 2023 - 07:07 AM
what year is yours?
1980
Posted 19 January 2023 - 07:09 AM
Just change back to your old ones??
Yes I will do that this weekend but they are pretty bent and rusty so I want to replace them. Just not sure if they were the right ones in the first place. And as the bonnet was positioned with the QR ones I hope it doesn't mess the gaps up
Posted 19 January 2023 - 07:59 AM
what year is yours?
1980
Mine was an 82 and they were that same as the round nose ones.
all I can suggest is post up some pictures. And as you change over some side by side pics.
i do remember things being tight when lifting the bonnet but no more so than any other Mini.
Posted 22 January 2023 - 01:52 PM
Posted 22 January 2023 - 03:16 PM
Looking at those pics it just looks like they put the slot in too deep.
not that I have anything to compare to but your look just like I expected.
Posted 22 January 2023 - 04:43 PM
The bonnet now opens further as is obvious from the extra curve on the hinge.
BUT.
It still doesn't pass the windscreen wipers. They are a set of minispares ones. The heavy duty version. Maybe they are deeper than standard? Or perhaps the bush kit need to be cut lower. Am going to Bingley so I can have a look at some options there
Edited by IronmanG, 22 January 2023 - 04:54 PM.
Posted 22 January 2023 - 05:23 PM
My original 1972 arms (fitted with 11" blades from an Austin 1300) sit lower and closer to the screen and give a minimum of 1/4" clearance with the bonnet.
Posted 22 January 2023 - 07:55 PM
I think a lot of the problem is that the currently available wiper arms seem to park the wipers an inch or two above the screen rubber and the arms protrude further from the screen.
Yep. And looking at yours I'm sure the wipers are thicker on mine. Only takes 5mm
Posted 22 January 2023 - 09:54 PM
Posted 23 January 2023 - 11:51 AM
DUF2 on the forum had the same problem - not sure how he resolved it, maybe drop him a PM
Lovely cheers
Posted 23 January 2023 - 12:52 PM
The hinges can't be the problem.
They'll all pivot around the same bolt located by the brackets on the body. The shape of the hinge only allows it itself to clear the scuttle panel. If you visualise a rod going through both hinge pivots; the offending bits of bonnet would describe a cylinder around that if it could swing through a full revolution. You need the wipers to be inside that. Moving that imaginary rod farther from the fouling bonnet and/or closer to the wipers, if possible to do it enough, will be the way.... or move the wipers.
Posted 23 January 2023 - 01:46 PM
I thought that the bonnet hitting the wipers was just normal. Mine on my Elf have always hit. I bought a set of the Minivation hinges made specifically for the Elf and they were just not worth messing with. I could never get the back of the bonnet to sit down. I put the old ones back on.
Edited by Red Riley, 23 January 2023 - 01:48 PM.
