Oil Smear
#16
Posted 23 January 2023 - 09:13 PM
NOT the PCV. I have known the PCV valve for years.
#17
Posted 23 January 2023 - 11:13 PM
#18
Posted 24 January 2023 - 12:31 AM
I believe that is a modern type PCV valve with spring loaded internal plunger and goes between the engine breather and the carbs tee,the correct way round.Steve..
Cheers Sonscar! What company sells this?
#19
Posted 24 January 2023 - 02:01 AM
Like this;-
As you don't have CCV Ports on the Carbs, I'd suggest connecting the Crankcase Breather tube to a PCV Valve, then to a T piece to the Brake Booster Hose, on the Manifold side of the Non-return Valve.
A after-market replacement type PCV Valve with 13 mm fittings for a small car would be fine.
#20
Posted 24 January 2023 - 01:31 PM
Luis
#21
Posted 24 January 2023 - 06:51 PM
Hi Spider, we definitely don't understand each other. I was asking about this new valve you showed me. If adapting it I don't need to buy the PCV one. And what company sells it? That's all.
Luis
Hi Luis, yes, we are not understanding each other too well.
We have many local sellers of the PCV Valve, but they aren't international stores. Most Auto Parts Stores have them. The one I posted here was likely from a Toyota Corolla. Is this what you were asking ?
#22
Posted 24 January 2023 - 09:46 PM
Luis
