Tensioner
Posted 31 January 2023 - 05:08 PM
Regards
Posted 31 January 2023 - 05:12 PM
As best I know, the Dulpex ones have not been available since the 1990's. I've only ever run a Simplex tensioner here (some going back to the early 80's) and never had an issue, but all those I have run have been genuine. Some people have had issues with after-market items.
Posted 31 January 2023 - 05:57 PM
I don't recall ever having seen a duplex one
Posted 31 January 2023 - 06:18 PM
What I want is a tensioner like the one in the photo.
Posted 31 January 2023 - 06:31 PM
I've not seen one either, Des Hamil refers to them in one of his books, apparently they were made for a Metro Racing series.
Thanks. It seems that wanting to give the best explanation I can't get them to understand me well.
That's a simplex tensioner.
Posted 31 January 2023 - 07:07 PM
Posted 31 January 2023 - 07:33 PM
Ok. What I don't want is for the tensioner to break, because I've read that in old threads in this Forum. So the question is: I'm doing the right thing fitting a tensioner like the one in the photo?
If you want to fit on then you have to fit the A+ front plate and use the A+ timing gear cover.
from what I understand you have an A series front plate and cover. So unless you go for the DSN or MED cover you can’t fit a tensioner anyway.
Posted 31 January 2023 - 08:32 PM
If you want to fit on then you have to fit the A+ front plate and use the A+ timing gear cover.Ok. What I don't want is for the tensioner to break, because I've read that in old threads in this Forum. So the question is: I'm doing the right thing fitting a tensioner like the one in the photo?
The MED cover doesn't won't take a tensioner.
Posted 31 January 2023 - 09:13 PM
Yes Nick. I'm going to fit a new A+ front plate and this timing cover:
Posted 31 January 2023 - 09:19 PM
Cheers imack! Beautiful engine. Unfortunately I couldn't get that timing cover from MED. IT is out of stock.The MED cover doesn't won't take a tensioner.If you want to fit on then you have to fit the A+ front plate and use the A+ timing gear cover.Ok. What I don't want is for the tensioner to break, because I've read that in old threads in this Forum. So the question is: I'm doing the right thing fitting a tensioner like the one in the photo?
Edited by PACINO, 31 January 2023 - 09:21 PM.
Posted 31 January 2023 - 09:33 PM
How high are you going to be revving the engine. I recall people advising the use of tensioners on lower revving engines but not on high revving engines.
Posted 31 January 2023 - 10:29 PM
I once had the pressure pad on a simplex tensioner split when used on a high-revving duplex chain set-up. I assumed it was because the points of contact are normally on each side of the pad with a simplex chain, but in the centre there is a single line of contact. Probably not a problem so long as a quality tensioner is fitted and changed regularly.
Posted 31 January 2023 - 10:30 PM
Luis
Posted 31 January 2023 - 10:31 PM
Tomorrow I'm going to ask where I bought the duplex chain Vernier (MED) if it is mandatory to adapt the tensioner, or not.
Regards
Luis
Edited by PACINO, 31 January 2023 - 10:43 PM.
Posted 31 January 2023 - 11:31 PM
Yes.
The one in my wife's Moke has done near on 300 000 km without issue.
The one in my own Moke has done just over 150 000 km without issue.
These engines regularly see 6000 RPM and cruise for weeks at a time on 4000 RPM.
They are originals though from the 80's.
