Hi
I have the 2 cv joints off the car
(Doing a rebuild)
I've rebuilt and refurf pot joints.
Wondering can you do the same for the cv joints
They are in good condition.
Cv Joint
cristiano1968
, Feb 02 2023 04:27 PM
3 replies to this topic
Posted 02 February 2023 - 04:27 PM
Posted 02 February 2023 - 05:12 PM
Sure. But I would not pop the bearings (balls) out just soak in a degreaser to get the old CV grease out and then add new. The reason not to remove the balls is they should go back into the same place in the outer and inner.
Posted 02 February 2023 - 05:31 PM
👍 ok thanks
I refurbished the pot joints
I did take them apart
Also the ball bearings
Degreasd but the balls went back in not the same as they came out
Is that bad
All the parts were in good shape
Is that bad
Posted 02 February 2023 - 07:37 PM
It’s the best you can do now and many of us have done the same. But it is not correct and wear may now happen faster.
