Spot Light Indicator Wiring Issue
Posted 05 February 2023 - 02:35 PM
My mpi has 4 spots at the front from factory. Today when I took her out I indicated right and the spot lamp flashes twice before the indicator then comes on. Same for left indicator. Then when I press the immobiliser the side lights light up and the front left middle spot lights up. Totally bizarre and come out of nowhere. Any ideas where to begin?
Posted 05 February 2023 - 03:09 PM
Posted 05 February 2023 - 06:46 PM
Prevent issues but clean any connections that look greeny in colour...
Posted 06 February 2023 - 02:00 PM
See below the MPI earthing point connectors as identified in the wiring diagrams. In my experience the LH header C550 is particularly vulnerable.
C361 Earth eyelet - radio Behind centre of facia
C556 Earth eyelet 1 RH side of engine compartment
C557 Earth eyelet 2 Luggage compartment LH
C558 Earth eyelet 3 RH side of engine compartment
C559 Earth eyelet 4 Luggage compartment LH
C560 Earth eyelet 5 RH side of engine compartment
C561 Earth eyelet 6 Beneath rear seat
C550 Earth header 1 LH side of engine compartment
Edited by Deeppockets, 06 February 2023 - 02:02 PM.
Posted 06 February 2023 - 06:31 PM
Posted 07 February 2023 - 02:51 PM
disconnect earths form bolt clean up with wet and dry paper and put a dab of battery grease or petroleum jelly on them to protect from corrosion in future. def, souns like an earth fault these always do weird things
