Eye Rod Extension Yoke?
3 replies to this topic
#1 MartinML
MartinML
  • 29 posts
Posted 07 February 2023 - 01:21 PM
My gear stick seems rather sloppy.
What's causing the inaccuracy?
Do I need a new gear lever or eye rod extension yoke or both?
This is a video of the second gear being engaged.
https://www.youtube....rts/BAKfE8AIcGQ
#2 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 07 February 2023 - 02:28 PM
Rod change?
If yes, I would suggest to check the two rubber cotton reels holding the gear change housing to the tunnel. They may be gone. New ones are harder and this may solve or correct the issue.
#3 Spider
  • 15,684 posts
Posted 07 February 2023 - 05:24 PM
There's many parts in the system that wear and all add together to make the shift sloppy.
A few more common bits to go are, as Giles mentioned above ^, the mounts. As well as these, the Roll Pins and Coupling at the back of the Gearbox also wear badly.
Looking at your video, the slot on the side of the Gearstick, down on the larger ball is worn. You can overcome that by replacing the Gearstick or you can weld around the slot and grind the slot back in.
#4 Steam
Steam
  • 933 posts
  • Local Club: Victorian Mini Club
Posted 08 February 2023 - 05:58 AM
Its not that bad! You are not belting your knuckles on the dash yet. ;-)
