Compression Ratio For 200+ Bhp
5 replies to this topic
#1 Racer_Pete
Racer_Pete
  • 2,492 posts
Posted 18 February 2023 - 06:37 PM
Hi guys, I'm currently collecting parts for my Morris Ital van that I'm boosting. I will be using a good old T3 turbo.
10 years ago I did the same on my mini, using a genuine 1275 metro turbo block and pistons. I was running 14psi of boost and was a good laugh, it had a modified head, cam, brand new T3. I never had it on the rolling road but from others running a similar spec I guessed it was around the 140bhp mark. Didn't know what the compression ratio was on it.. a bit silly I know.
My question is what compression ratio should I am for, I know that a too low compression ratio will cause it to a bit of a dog off boost, but I don't really mind that, (to a certain extent) I was thinking around 8.1:1 C/R and running around 18/20psi. I have seen others running even lower and obviously gaining more power.
Also what spec cylinder head would you go for regarding what size valves.
So the spec I am going for with this build is-
A+ 1293cc
Reconditioned T3 turbo
(Cylinder head undecided on spec)
+20 Forged omega 18cc Pistons
Ph2 turbo cam
Aldon turbo dizzy
big front mount intercooler
Swiftune alloy/alloy duplex
2" maniflow exhaust system
ARP con rod bolts
ARP 11 head stud kit
Final drive 3.6:1
Thanks.
#2 johnv
johnv
  • 498 posts
  • Local Club: FDMC
Posted 18 February 2023 - 08:56 PM
200 bhp? For how long …
#3 Steve220
Steve220
  • 5,047 posts
  • Local Club: BMC
Posted 19 February 2023 - 08:24 AM
Loads of A series turbo engines are 200bhp+ now. Just need to make sure its fuelled and cooled correctly.
#4 Nial81
Nial81
  • 30 posts
Posted 19 February 2023 - 10:19 AM
Going for that power I'd think you'd want to ditch the dizzy for a 3d mappable ignition system and a more modern turbo than a T3 like 1752 will make that power more efficiently. Managing heat and ignition properly will allow a higher CR. I'd think you'd need some gearbox mods to run that power and an RTS clutch.
#5 Steve220
Steve220
  • 5,047 posts
  • Local Club: BMC
Posted 19 February 2023 - 01:54 PM
The gt20 is far better for 200bhp
#6 PoolGuy
PoolGuy
  • 848 posts
Posted 19 February 2023 - 03:22 PM
It's going in a Marina van , so the cooling won't be a problem, RTS clutch isn't relevant and the gearbox will be the best bit of the build, I agree about the mappable ignition though, it'll be well worth it.
