Straight Cut Gears
21 replies to this topic
#1 Mush 78
Mush 78
    Starting My Mini Up
  • 3 posts
Posted 25 March 2023 - 08:20 AM
Straight cut gears where is best to buy ?
MED look good quality but pricey.
What do you have in your minis ?
#2 Steve220
Steve220
  • 5,075 posts
  • Local Club: BMC
Posted 25 March 2023 - 10:52 AM
MED, KAD, Guessworks
#3 MiniMadRacer
MiniMadRacer
  • 893 posts
Posted 25 March 2023 - 11:05 AM
I use the Minispares Clubman A+ set
#4 Midas Mk1
Midas Mk1
  • 5,789 posts
  • Local Club: S.U.N.M.C
Posted 25 March 2023 - 11:25 AM
Google broken?
#5 DeadSquare
DeadSquare
  • 3,205 posts
Posted 25 March 2023 - 12:01 PM
I have had BMC Special Tuning Straight Cut Gears in my 850 Mini Se7en for 50 years, and I have never had a problem with them.
#6 imack
imack
  • 2,211 posts
Posted 25 March 2023 - 12:03 PM
I'm running the minispares 6 piece ST sccr gearset for remote box, Minispares primary gear and input gear, MED roller bearing idler gear and MED sc crownwheel and pinion. I suspect they may all be from the same source.
#7 nicklouse
  • 18,724 posts
Posted 25 March 2023 - 02:12 PM
It all depends on what you are going to use the car for.  For road use I would not fit straight cut gears.
#8 whistler
whistler
  • 1,831 posts
Posted 25 March 2023 - 04:53 PM
I have a minispares set and a guessworks set. Can't say there's any difference in quality. They are a lot quieter than the original Special Tuning sets though.
#9 Gaz66
Gaz66
  • 964 posts
Posted 25 March 2023 - 09:06 PM
I know Ive said it before but....Straight cut everything is the law in a classic mini 👍
#10 bpirie1000
bpirie1000
  • Area Managers
  • 2,398 posts
  • Local Club: Amoc
Posted 26 March 2023 - 08:17 AM
Do you own an ear defender company?
I do love the sound and raw engineering though....
#11 Baldspeed Racing
Baldspeed Racing
  • 1,195 posts
Posted 27 March 2023 - 03:30 PM
I run MED in mine as local to me, nice and strong and sound amazing
#12 coopertaz
coopertaz
  • 811 posts
  • Local Club: a-series-magpies
Posted 29 March 2023 - 09:14 AM
use clubman sccr from minispares good but don't use lower than 3.44 diff as first gear ends up too tall. fitted as love the noise but also don't get the drop between 2nd and 3rd that you get with standard gearing. don't forget silent in 4th as drive straight through mainshaft. avoid stright cut drop gears though they are v. noisy and a friend used to wear ear defenders when they fitted them.
Edited by coopertaz, 29 March 2023 - 09:15 AM.
#13 Cooperman
  • 23,340 posts
Posted 29 March 2023 - 03:20 PM
Top advice, especially re the final drive ratio. With a standard cam the 3.44:1 FDR is fine, but as soon as you fit a hotter cam and move the torque and power bands higher up the rev range, a lower FDR is needed. For example, with, say, a 286 cam the FDR needs to be around 3.9:1 which then gives a top gear of c.14 mph per 1000 rpm.  Thus 5000 rpm at 70 mph which is fine for competition, but not so nice on the road.
For a road car the best ratios are those of the original Cooper & 'S'. I have those in a road-rally Cooper with an MG Metro cam and a 3.44:1 FDR and that works very well. The biggest problem with the SC CR gear sets is the high first gear which means lots of clutch slipping can be needed to get away on a hill or at the traffic-lights GP unless a much lower FDR is fitted.
#14 Gaz66
Gaz66
  • 964 posts
Posted 29 March 2023 - 04:49 PM
Get those heads turning going down the high street with a full on whine, you know it makes sense 😊
I think Im still a boy racer even at 57 😂
#15 imack
imack
  • 2,211 posts
Posted 29 March 2023 - 06:18 PM
Dogs have taste and seem to appreciate the whine, their owners just stare at you expecting that your little 'clown' car is about to disintegrate!
