Heavy duty flywheel puller, complete with bolts for both verto and diaphragm flywheels. Very good condition.
£25.
Can post.
Posted 29 March 2023 - 06:01 PM
£25.
Can post.
Posted 07 April 2023 - 11:38 PM
Do you still have it available? I've gone through two of the cheaper versions up to now with a really stubborn flywheel.
Posted 08 April 2023 - 07:49 AM
Sorry now sold
Posted 08 April 2023 - 08:45 AM
In the early days of Minis, long before anyone but a BMC franchise had a flywheel puller, flywheel removal was usually due to oil on the clutch, and would be done with the engine in situ....as follows.
Remove the plugs, the starter and the grill.and hang an 1" round steel bar through the grill with the other end resting through the starter opening, and hit it 3 times with a heavy sledge hammer.
Rotate the flywheel about 150 degrees and keep repeating until the taper released.
Posted 08 April 2023 - 08:51 AM
Brutal and not a good idea these days when Mini parts are no longer cheap as "chips"... you can damage the taper on the crank and or warp the flywheel
