Seized Brake Nipples
23 replies to this topic
#16 sonscar
sonscar
  • 3,062 posts
Posted 23 April 2023 - 02:27 PM
You should never have leakage past the threads,the taper or copper washers seal.Steve..
#17 DeadSquare
DeadSquare
  • 3,205 posts
Posted 23 April 2023 - 10:21 PM
Wrap 2 turns of PTFE plumbers tape round each hose, pipe nipple, anti-clockwise, so that it doesn't ruck as you screw them up
That's a brilliant idea, so obvious I didn't think of it.
Not only will it help prevent them seizing, it should reduce leakage around the thread making them function better too.
24,948 posts later, and it has finally been worth joining The Mini Forum,  Lol
#18 Ethel
  • 26,108 posts
Posted 23 April 2023 - 11:28 PM
Bleed screw - seals by the pointy end in the hole before the threads. Once they're cracked open some fluid can come up the threads. Worse still, air can get sucked the other way.
#19 andyapanel
andyapanel
  • 627 posts
Posted 24 April 2023 - 05:53 AM
I used a surface drive spanner when I had this problem, with plenty of plus gas and patience.
Good luck.
#20 smurfomatic
smurfomatic
  • 461 posts
Posted 24 April 2023 - 07:40 AM
Good luck.
I haven't run out of Plusgas yet...ran out of patience a while ago!
#21 smurfomatic
smurfomatic
  • 461 posts
Posted 24 April 2023 - 08:46 PM
Here's my shopping list from Minispares...have I missed anything?
Edited by smurfomatic, 24 April 2023 - 08:47 PM.
#22 sonscar
sonscar
  • 3,062 posts
Posted 24 April 2023 - 09:18 PM
I find more success when using six point sockets and slightly tighten first.Steve..
#23 stuart bowes
stuart bowes
  • 2,264 posts
Posted 24 April 2023 - 11:09 PM
^ exactly this when I had to sort them out on the volvo a while back (and then removed all and replaced for good measure)
started with correct sized open spanner but the first one started to round off almost immediately, are they made of something soft or what
Edited by stuart bowes, 24 April 2023 - 11:11 PM.
#24 kartman
kartman
  • 62 posts
Posted 25 April 2023 - 01:08 PM
You need a set of these, perfect for rounded off nipples and other rusted nuts/bolts you come across, used on my mk2 golf ones at the weekend and replaced with new nipples.
https://www.screwfix...set-6-pcs/6083d
Not sure if they go small enough for the rears though but be fine for the fronts.
