Switching to flat top pistons, so I need to recalculate my CR and do some adjustments as my head volume is too low (ie current CR is too high).
Block was previously decked so that the pistons come up flush with the block at TDC. With these flat top pistons however they appear to be ever so slightly shorter, average depth from the block face at TDC is 0.18mm (at least according to my vernier caliper).
Head was previously skimmed to increase the CR when i was using dished pistons. Just checked the volume with the water + syringe method --> averages to 20.1cc
I'm back to a standard 998 bore, so diameter = 64.15mm, depth (at BDC) = 76.67mm.
Swept Vol = 247.8cc (pi * 3.2^2 * 7.67)
Unswept Vol = 25.44
That means the CR is 10.74.
Now, considering that adjusting the timing hasn't helped with pinking even with RON 97 fuel and just the lightest touch of the throttle, I'd reckon the CR is closer to the high side of that range.
Suppose I target a CR of 9.6 (since thats about the most you can have if you want to use RON 95 fuel) that means I need to increase the Head's chamber vol from 20.1 to 23.5cc.
The big question is, how do I ask the machine shop to cut away at the chamber to achieve this? here's a picture of my head. The boundaries of the Head gasket are clearly visible, so there's quite some room to cut away. I suppose I can cut away at this lip here? Is it going to be a trial and error process where they keep shaving away at the metal and measuring the volume? or I suppose I could approximately calculate how far to cut that would give me my target volume?
cylinder_head.jpg 38.95K
3 downloads
Edit: Updated measurements and CR after taking more accurate measurements
Edited by BaronVonchesto, 01 May 2023 - 12:39 PM.
