I’ve been adjusted my lost gap today on my 1993 SPI. I’ve been following the instructions perfectly on memsfcr.co.uk.
At what point are we checking the lost gap? Mine is not centred with the ignition off. But if I turn the ignition on and manual move the throttle cam it settles in the centre (I’ve adjusted it to centre at this point). Is this normal??
Also
When I turn the ignition on. My steeper motor clicks away. But it doesn’t make any noise when I turn the ignition off. Is this normal?
For info. Car has been idling perfectly. Just doing routine maintenance. Making sure it’s set up correctly.
Thanks in advance for any help!!
Lost Gap/steeper Motor
Bobs2293
, Apr 30 2023 09:56 AM
2 replies to this topic
Posted 30 April 2023 - 09:56 AM
Posted 01 May 2023 - 11:00 AM
Hi,
According to memsfcr page the ecu should "remember the settings" which is a rather odd statement considering adjusting the throttle cable has nothing for the ecu to actually remember. Mine is centered with the ignition off, but that's how I centered it, I didn't do the ignition on - throttle movement bit, which is my error. I will go back and re-check mine with this method when I get a chance.
My stepper motor moves when I turn it on AND when I turn it off.
Wish mine would idle perfectly lol
Posted 01 May 2023 - 02:54 PM
The stepper is probably operating correctly,going to home when turned off and then opening a remembered number of steps when turned on.Steve..
