Brake Warning Test Switch.. Necessary?
#31
Posted 05 May 2023 - 05:29 PM
Which generally is not out of sight by your left knee...
#32
Posted 05 May 2023 - 05:33 PM
Bear in mind I'm only working on the loom on a table I don't have the car running in front of me so here's the mistake (I think)
I was assuming there was a light on the dash for brake fluid low which the switch would illuminate.. but now I'm thinking there isn't
I have a 3 binnacle setup by the way
So there's one red light I can see I'm guessing that's the oil warning (just a light no symbol?)
And the brake level warning would only be on the switch which I twigged after reading KTS post
So going back a few steps and starting again..
The point of spiders mod is that red light on the dash will now light up for oil fault OR brake fault or (unlikely, but) both
So I can inform MOT man of this mod if he asks, get rid of the switch, and if required prove it by pulling the lid off the master cylinder and the light comes on
Does that make sense now hopefully I've got the right end of the stick
Edited by stuart bowes, 05 May 2023 - 05:35 PM.
#33
Posted 05 May 2023 - 05:39 PM
On the black/ white cable before it joins the white/ brown
Or.. join the two together then put the diode after that then into the oil sensor
#34
Posted 05 May 2023 - 05:49 PM
it seems you haven't quite understood what Spider put forward
on the schematic you'll see that there are two lamps present; one for the oil pressure warning and one for brake fluid
as mentioned previously, what the solution does is basically use the operation of the oil pressure switch (..which is an electrical switch..) as a replacement for 'press-to-test' function of the dash switch
the diode is needed to prevent the 12v from the oil pressure warning circuit to back feed through the brake fluid warning lamp when the oil pressure switch is open (i.e the engine is running)
to answer your previous question : yes; with that system the brake fluid warning lamp would illuminate when no oil pressure exists
#35
Posted 05 May 2023 - 06:32 PM
And I've just cut my manky old master cylinder lid in half to check how that works (so gunked up I couldn't get a continuity test) and confirmed the same there, low fluid = closed circuit
So all I actually have to do is totally delete the switch, forget the diode, and add the black and white wire to the brown and white.
So if oil switch closes the red dash light comes on (fault indicated) and if the brake fluid drops low enough, that same light comes on (fault indicated) either way a closed switch has provided earth to the circuit and I get a light
Essentially providing a bypass to earth via the brake fluid level switch
and in the unlikely event of brake and oil fail that circuit just has two earths which makes no odds
Seeing as it's just a red light basically it just means fault, pull over and stop straight away.
I'm sure I can get that past the MOT man and it's provable by taking the lid off the master cylinder and letting the fluid drain from that little capsule to create a low fluid warning
Also with no switch in place it doesn't fall foul of the 'if fitted' rule
Besides which, with mot free time coming up fairly soon it won't be an issue for long
That would leave me happy that I've got a sensible working warning system anyway
Edited by stuart bowes, 05 May 2023 - 06:45 PM.
#36
Posted 05 May 2023 - 06:51 PM
#37
Posted 05 May 2023 - 07:05 PM
Having checked again.. oil/ brakes will be orange. Red is ignition light
I took the bulbs out and used my phone torch from behind to check after following the wiring / pcb paths
Edited by stuart bowes, 05 May 2023 - 07:06 PM.
#38
Posted 05 May 2023 - 08:14 PM
There is a spare bulb position in the cluster.
Depending on the year, it's either at the bottom of the Speedo or top of the Fuel / Temp.
I think some also had a further spare spot in the Tacho.
#39
Posted 05 May 2023 - 08:28 PM
cheers, but to be honest I'm pretty happy to leave it as it is now, seeing as the lamps are not labelled and have no symbols anyway, what difference would it really make
actually I like the fact that orange is now just a general fault indicator, it's like the EML symbol on modern cars
thanks anyway though and appreciate your pointers earlier which led to the solution in a roundabout way
Edited by stuart bowes, 05 May 2023 - 08:29 PM.
#40
Posted 06 May 2023 - 08:00 AM
Asked him about this in passing and his opinion was, if the light on the button was lit up he'd check the reservoir. If the reservoir was filled ok he'd assume the sensor failed and just pass the car anyway (assuming of course brakes pass tests)
On his own one he can't remember the last time he pressed it no idea if it works, would be too worried the switch would just break if he tried lol
Uses the usual method as I said right at the start, checking fluids under bonnet on regular basis
His opinion, just lose the switch . Told him already rewired and explained setup as above and he liked the idea and said yeah fair enough
#41
Posted 06 May 2023 - 09:42 AM
Simplest was to pinch a Metro handbrake lever which was the same, but with a switch. You could use a brake light switch, courtesy light switch, or any "push to break" switch mounted where the handbrake will open it when it's off.
Ignition feed to a brake warning light, then on to earth via your handbrake switch as well a separate earth via the fluid level switch. As a bonus you're reminded when the handbrake is still on.
#42
Posted 06 May 2023 - 10:44 AM
Why would you not want this?
That's good enough for me. As for "why wouldn't you want it", I (as above) prefer to check safety critical items regularly rather than rely on a potentially unreliable warning system to tell me that something may not be working.
#43
Posted 06 May 2023 - 09:19 PM
His opinion, just lose the switch . Told him already rewired and explained setup as above and he liked the idea and said yeah fair enoughThat's good enough for me. As for "why wouldn't you want it", I (as above) prefer to check safety critical items regularly rather than rely on a potentially unreliable warning system to tell me that something may not be working.
I always thought it very unlikely that you could lose so much brake fluid for that light to come on without knowing about it anyway. But maybe you can.
#44
Posted 06 May 2023 - 09:42 PM
As Brake Shoes wear, the level in the Reservoir will drop. if they are not adjusted back. Likewise, with Discs, as the Pads wear, the fluid level will drop.
With the Yellow Tag Maters, they way that it's necessary to plumb it up, with the Top Port to the Front Brakes, that has the smallest Reservoir and will in fact run dry before too long with regards to wear - in the case of 8.4" Discs, around 1/4 wear on the Pads in enough. This is why these Master Cylinders are illegal here (Australia).
I'll add too (and yes I tale on board what the MOT man has said), things think these they don't add to cars to increase sales of them, they most likely did this to meet regulations.
#45
Posted 06 May 2023 - 11:32 PM
But with what you've said just there actually it corrected us on that point then
My master cylinder does indeed have a yellow tag. I assume that's a global standard then and no difference between your yellows and ours
Edited by stuart bowes, 06 May 2023 - 11:33 PM.
