Hi CHris, I think it's different, that would be the the thing that actuates the self cancelling ring. Well I do need one of those, for when I replace the removable steering wheel.
The broken bit is the actuating ring - it's black and comes with a new indicator stalk set. You can see its genrtal shape and location here, standing proud on item no. 6, which simply locates in the centre as a separate ring, but isd not fixed with a screw and rotates: http://www.minispare...es.aspx?1~10~92
When the part you show moves, fixed to the column as it is, it turns that (loose) actuating ring which then cancels the indicator by returning it to central position... (with some more fancy magic).
Note: I call it an 'actuating ring'.. not sure what others may call it.
Edited by chuee, 06 May 2023 - 06:36 PM.
