Hello,
On my 79 1275GT Clubman, I just got some of those ClimAir wind deflectors from Minispares for the front windows.
They install under the window rubbers.
However with the drivers side installed, the window gets to about 1cm from the top and will not go up any higher, as the space the wind defector takes up beside the window rubber, causes a pinch point which is just too tight to push the glass through.
You can see the step the deflector makes in the rubber, and its right at that point the window binds.
Is this common?
To make it worse, I just installed the Minispares Electric Window kit, so I cant crank the handle to force it up, as the motor just stalls and wont go up any further.
Before installing them, the motors will raise and lower the window rather nicely with no pinch points.
I have just installed some new Phoenix window rubbers too. I had Minispares rubbers up till now, but they bind while the Phoenix ones do not, they have a slightly different profile where the glass slides on the felt.
Anyway, these were not that cheap just to take off and not use, so am curious if this is common, or if I need to do something different?
Tempted to somehow stick them on the outside of the door rather than sandwhiched in the channel, as then they wont cause an issue with the glass, but they are not designed for there specifically...
Any ideas?
