Thanks Spider.What these variations suggest to me from experience is that at some point, the Idler Gear Bearing has been replaced by heating the case and / or the Flywheel Housing is not aligned to the Gearbox.
Can you kindly through up some photos of the shafts of the Idler Gear ?
I forgot to say above that I am just turning the thrust washer. Everything else was stationary under testing.
Heat has been applied to the transfer case in its time, but checked with another transfer case that I am pretty sure hasn’t been heated, and with the same result, though will double check this.
I’ll pop over to the garage later, and take a few snaps of the orig idler gear that got pitted, the new idler gear, and a spare I have, ( which belongs to another box, that I used for testing). Its the new one that was used in the last test and the one i plan to use.
Edited by lildeucecoop72, 15 May 2023 - 11:38 AM.
