Replace Or Renovate Brake Callipers
Posted 26 May 2023 - 08:05 AM
I’ve had it sorn since COVID. Now have a bit of time to get it running again. I think the callipers are sticking on one side. (One side locked up when I tried braking at low speed).
What’s suggestions please.
The pads and discs already need changing.
I would like to keep things as original as possible as is everything else on the car. Although I don’t have much in depth mechanical experience.
So should I replace like for new like callipers or renovated (or get someone to renovate) the originals.
What’s best?
And best place for parts?
Posted 26 May 2023 - 08:27 AM
If the general condition of the castings are OK, then recondition what you have.
Posted 26 May 2023 - 08:29 AM
They might free off if it's just from lack of use.
Pop one pad back in (with the other 3 brakes fully assembled!) stand on the pedal once to push the padless piston farther out. Inspect the piston for rust & crustiness & clean/scrape as appropriate. Push the piston back in, there are tools, but levering with a big spanner works. Pop a pad back in & do the other side of the caliper.
It is possible to eject the pistons, but they're designed to wear the pads down to the metal without that happening. After a few times you should be able to judge it well enough & find that you can push one piston out by pushing the other in, which is a fair indication they are freed up.
The actual fluid seal is a good way inside the caliper, so even if the piston is crusty where you can see it, it may well be ok where it matters, for now at least.
Posted 26 May 2023 - 10:55 AM
I sometimes get a random bit of metal thinner than the brake pad (1/2"spanner) stick it where the pad on one side goes then pump the pedal. Then clean it up and push piston back.
Repeat if necessary...
