5000 Rpm Miss
27 replies to this topic
#16 timmy850
timmy850
  • 3,391 posts
  • Local Club: MITG
Posted 29 May 2023 - 07:21 AM
Do you know what timing advance you’re getting at 5000rpm?
#17 bajean
bajean
  • 125 posts
  • Local Club: Malta Mini Owners Club
Posted 29 May 2023 - 07:28 AM
I believe its 34. However i only changed the inlet manifold and nothing else
#18 bajean
bajean
  • 125 posts
Posted 29 May 2023 - 08:05 AM
Edited by bajean, 21 July 2023 - 11:37 AM.
#19 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 29 May 2023 - 08:33 AM
Custom needles need to be made on the engine they are used for.
Ac
#20 Lplus
Lplus
  • 911 posts
Posted 29 May 2023 - 12:01 PM
A decent pair of custom needles will have this right in 30mins.
Ac
You dont happen to have a set lying around i can buy…… In the meantime i’m gonna give the AAU needles a go. I also have an AEM afr gauge ive been planning to install for the past year and still haven’t done it, so this would be the perfect time for it.
AAU needles are quite a lot weaker than AAC.  I also bit the bullet and shelled out for an AEM A/F meter and it's been worth it.
#21 bajean
bajean
  • 125 posts
Posted 29 May 2023 - 01:06 PM
After comparing some needles on http://www.mintylamb.co.uk/suneedle , i think ill give the AAA a go. They have almost the same fueling low to mid but at high revs they are slightly leaner. However I really do need to hook up that afr gauge to see whats really happening.
Edited by bajean, 29 May 2023 - 01:15 PM.
#22 imack
imack
  • 2,207 posts
Posted 29 May 2023 - 02:48 PM
Ac
AAC are miles weaker than AAU
#23 bajean
bajean
  • 125 posts
Posted 29 May 2023 - 03:29 PM
Plan is to try AAA and AAU. I never mentioned AAC. since they are considerably weaker than my engine needs. Thanks everyone for your input greatly appreciated !
Edited by bajean, 29 May 2023 - 05:48 PM.
#24 Lplus
Lplus
  • 911 posts
Posted 29 May 2023 - 07:13 PM
Ac
yep, my mistake.
#25 cal844
cal844
  • 9,648 posts
  • Local Club: TFMOC
Posted 29 May 2023 - 07:51 PM
Ac
An AAC wouldn't run my 1275 or 998s with stage 1 kits, fit the AAU and it's in the ballpark... They then need fettled slightly and only someone with the right training and equipment can get them bang on.
#26 timmy850
timmy850
  • 3,391 posts
  • Local Club: MITG
Posted 29 May 2023 - 09:06 PM
Sorry but how do you know what the engine needs without measuring the afr?
#27 bajean
bajean
  • 125 posts
Posted 30 May 2023 - 09:34 AM
I had found this article which gives you a vague idea of what needles to use as a starting point. Once again an AFR gauge will be installed to actually see what the engine really needs.
#28 bajean
bajean
  • 125 posts
Posted 25 June 2023 - 05:18 PM
So i finally had some time to play around with the mini. Upon further inspection it turns out that the brand new 100 euro MSD coil has s….t itself. Replaced it with my old Lucas gold coil and surprise… no more miss and even seems to idle and drive better.
